  New Posts New Posts RSS Feed: black tank
black tank
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Topic: black tank
    Posted: 26 Sep 2023 at 2:25pm
The 177 might be similar to the 179. The pipe between the toilet and the tank did have a curve to it. Always make sure to use plenty of water when flushing anything but liquid to help stuff move past the offset and into the tank. I'm not sure what mechanism you are referring to. The valve isn't a straight flap. Is it a ball valve instead of just a flap?
hogone View Drop Down
Post Options Post Options   Quote hogone Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2023 at 9:52am
I was just going to post a similar question only mine I believe is clogged up top.   I can see t paper stuck. I always thought the tube went straight down but not I think it curves in. Also what is that little mechanism that you can see below the flap.   Seems everything is stuck around that. Advice appreciated. Jon
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 9:45pm
Use a good biological agent in your tank to break down the waste and TP. I'm currently using Happy Camper. I've also used RV Digiest-it, or other biological agents. Don't use anything with Formaldehyde.
ilthyn View Drop Down
Post Options Post Options   Quote ilthyn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 8:16pm
Thanks. A good doze of Drano seems to have cured the problem. My lady says the TP we used was not proper RV type although I bought it at an RV dealership/
2011 Pod 171 with numerous mods.
2013 DODGE RAM 1500
Post Options Post Options   Quote ilthyn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 8:15pm
2013 DODGE RAM 1500
Post Options Post Options   Quote lostagain Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 6:35pm
Post Options Post Options   Quote ilthyn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 4:35pm
I believe the outlet is plugged. I have bought a Drano product that includes a spiked plastic flexible wand about 58 cms long. Will try it out tomorrow after the gel has had a go at the blockage.
2013 DODGE RAM 1500
Post Options Post Options   Quote ilthyn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 4:32pm
Thanks. I found a Drano product that includes a 58 cm spiked plastic wand. Going to try it out tomorrow after the gel hopefully does its thing. Cheers.
2013 DODGE RAM 1500
seafans View Drop Down
Post Options Post Options   Quote seafans Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 1:12pm
https://www.campingworld.com/flexible-tank-wand-14497.html
Only a suggestion.
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 9:58am
Define plugged. Is the outlet clogged?
