Replacement for LED dome lights |
kansasfrogs ![]() Groupie ![]() ![]() Joined: 21 Jul 2016 Location: KS Online Status: Offline Posts: 83 |
![]() ![]() ![]() ![]() Posted: 14 Jun 2023 at 6:29pm |
I have been unable to find exactly where to get these. The number on the inside where the little LED panel is 22779-091 12V - V10. I had to order the entire dome with panels in it, but it didn't seem to work for my 182 G 2015 RPod. Also there don't seem to be any alligator clips and it appears to be hardwired in. If you have replaced yours, what did you order? I saw these on amazon.
Leisure LED 5 Pack RV LED Ceiling Double Dome Light Fixture ON/Off Switch Interior Lighting for Car/RV/Trailer/Camper/Boat DC 11-18V Natural White 4000-4500K 48X2835SMD (Natural White 4000-4500K, 5) |
FROGGY
hank*pod ![]() Groupie ![]() ![]() Joined: 06 Oct 2022 Location: PA Online Status: Offline Posts: 63 |
The wrong part would still work if it's designed for 12 volts and wired properly.
Thanks for your reply!
FROGGY
Ben Herman ![]() Senior Member ![]() Joined: 26 Apr 2018 Location: Gr Junction, CO Online Status: Offline Posts: 356 |
I ordered these when I wanted to add two more lights under a shelf that I built. They are a prefect match.
Facon 3-1/2'' LED RV Puck Light Super Slim Under Cabinet Light, 2-Packs Surface Mount Ceiling Dome Light with Push Switch, 12V DC Interior Light for RV Camper Trailer Motorhome, 3400K Warm White LightIt was 4 years ago s I am not sure if the product has changed, but at least itll get you in the right direction
Bad link format; try this:
https://www.amazon.com/gp/product/B075KNHTQ1/ref=ppx_yo_dt_b_asin_image_o00_s00?ie=UTF8&psc=1 |
FROGGY
