Bent Axle |
Page 12> |
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3345 |
![]() ![]() ![]() ![]() Posted: 19 Jun 2023 at 6:24pm |
Anything is possible and on ours the passenger side is totally straight, it is on the slide side where our issue lies, like stated before, it has a 1" toe in at the top yet after 5 years and 20,000 plus miles, there is still plenty of wear and rubber left on the inside of the tire where the greatest amount of wear is takes place.
DD08 ![]() Newbie ![]() Joined: 05 May 2023 Online Status: Offline Posts: 12 |
I am in the process of ordering a new axle.. however upon further inspection I took a look at the tire wear pattern and it's actually only on the passenger side on the inside of the tire. The drivers side is showing signs of wear but nowhere NEAR how bad the passenger is.
Is this giving me clues to the Axle not being bent and something else? The spindle that holds the wheel possibly? I've seen another post somewhere where they had a bent spindle and not the axle.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6425 |
Agreed!
The cantilever design of the walls also is a weak point, particularly with the weight of the slide-out. The aluminum frame of the RPod floor is okay for something that does not bounce down the highway.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2708 |
I don't believe the torsion axles are the issue so much as the cantilever design where the axles extend beyond the frame by a foot or more. If the frame went all the way to the outer wall of the chassis, there would be far fewer issues.
hank*pod ![]() Groupie ![]() ![]() Joined: 06 Oct 2022 Location: PA Online Status: Offline Posts: 63 |
Are the tires directional? You could just remount the tires the other way on the wheels.
I love the way your proposal addresses the visible symptom without dealing with the root cause. ![]() |
ArenaBlanca ![]() Senior Member ![]() ![]() Joined: 07 Sep 2016 Location: Alamogordo, NM Online Status: Offline Posts: 158 |
Has anyone tried swapping the wheels on the camper so the other edge of the tire would experience the excessive wear pattern? If you just swapped the wheels, the inside of the tire would still be on the inside. So you would have to dismount the tires from their hubs and swap tires and hubs for this to work. I noticed the wear pattern about 2,500 miles into this year's outing. But I was encouraged by jato's comment and decide to wait until I get home. I think I probably got the bent axle last year on our Alaska trip, so the wear has developed over the last 7,000 miles. |
Enjoy Life!!
Eeeesh.
gpokluda ![]() Senior Member ![]() ![]() Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 399 |
I am beginning to find that bent axles, especially of the torsion variety, are common with RVs these days. Even with a semi-premium brand such as Escape, folks are experiencing abnormal tire wear due to bent axles. A couple of posters even go so far as to say that axles on newer RVs should be considered consumables just like bearings, brakes and tires.
Gpokluda
Thanks Jato/Stephen,
Appreciate the input, I think when we hear bent axle not having much knowledge on R pods and trailers we thought it was the end of the road and the thing was done. we got a second opinion on ours and the Axle is bent about 1/4", We're going to review replacing or just leaving it as is but we've had the tires for about 2 years and the wear appears pretty bad. Pictures to follow.
renhui ![]() Groupie ![]() Joined: 20 Jul 2022 Location: Calgary, Canada Online Status: Offline Posts: 63 |
I noticed some bent as well (top-in), will keep a close eye on it.
I've seen some videos on Youtube on fixing the axle, have any one tried that before at all?
Page 12> |
