  New Posts New Posts RSS Feed: First Time Towing!
First Time Towing!
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Topic: First Time Towing!
    Posted: 16 May 2023 at 2:51pm
To re-iterate on my earlier post about adding the 3.5" lift kit from FR:  It was an easy job, took me 1 hour to do the whole job using simple hand tools and torque wrench (6 years ago).  Since then we have taken some very steep back roads and inclines with no dragging of the rear stabilizers, it also helps that we have the nose of 177 1" low in the front than the rear - which also assists in keeping the tongue weight at 11% or better to reduce/eliminate sway.
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2023 at 9:37am
Originally posted by StephenH
The lift kit more than the 15" wheels.
For sure. The lift kit can get you an additional 2 or 3 inches, depending. The larger wheel only a 1/2 inch. Every little bit helps.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2023 at 5:24pm
+1 on different set-up needed for different vehicles. Unless both the Jeep and the truck have exactly the same hitch heights, you will need to do some adjusting. Get a torque wrench to assist in making sure the bolts are properly tightened.
Post Options Post Options   Quote lostagain Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2023 at 2:50pm
DDo8, if you get a WDH and plan to use it on different vehicles, you'll probably need to adjust it to fit and balance.  I can't speak for brands other than the Fastway e2, but they have a setup guide in their manual that should be helpful.
DD08 View Drop Down
Post Options Post Options   Quote DD08 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2023 at 12:38pm
Wow! All I can say is I'm grateful and amazed at the responses I've gotten on here. Honestly great solutions and I'm kind of relieved my situation is a little more in need of just using a bunch of wood ramps to try and get it up there.
+1 on the level kit honestly. We took another crack this weekend trying to take the driveway at an angle etc and no luck. If it wasn't the jacks, it was the spare tire, the bumper, the water drains.. it just wasn't going to happen. I couldn't believe how little clearance this trailer really does have.
Anyways a little update.. My uncle who tows a bunch of trailers daily came over and took a look. He had a hitch with a little more drop, but it appears it needed even more.. perhaps with some cargo in the bed and trailer it will level out the trailer a little more. Admittedly also that driveway is my parents, with my house next door. We eventually just took a path across my lawn onto my driveway for the time being as I don't have as severe as a dip. So finally we are off the street.
I went to the local trailer place around here and although it's pricey I'm going to go for the E2 hitch anyways, not only will it make the ride a bit better but I think it will be a requirement for my wifes jeep should we ever want to take the trailer with that. So it'll get some good use.
All in all I think it's just been a while towing a trailer and I wasn't used to the feeling behind the truck. I think it's just the nature of towing 3000 LBS and will eventually get used to it. I think I was silly to assume I'd feel absolutely nothing back there.
Thank you all again and will continue to participate in some threads on here!!
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2023 at 11:19am
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2023 at 9:44am
Good point. A lift kit, and maybe switching to 15" wheels/tires (LRD) would both help.
mjlrpod View Drop Down
Post Options Post Options   Quote mjlrpod Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 2:29pm
Surprisingly no one has mentioned adding a lift kit to the camper. They sell a 3 1/2 or 4 inch lift kit for the pods. It will make a huge difference on your ground clearance.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
James07 View Drop Down
Post Options Post Options   Quote James07 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 12:44pm
I have almost same set up.  2015 R pod 178 and new Ranger.  No problems towing with E2 WDH on 7,500 mile round trip California to Alaska last summer.  I added a second battery to give more weight to the front and carry very little water (since tank in back).  Only recommendation is that you get E2 with 450 or 600# trunnion bars.  Trunnion because of your driveway and 450/600# because the R pod is very lightweight and you want some bending.  Don't want it too stiff.
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 10:02am
One more thing. Backing up a trailer needs some practice, and do it with a spotter with a handheld radio if you can. Steer from the bottom of the steering wheel (if you want the trailer to go left, move the bottom of the steering wheel to the left). as soon as it starts moving the direction you want, follow it (straighten the turn a bit so you're following in the same arc). If it gets too far out of whack, do not be afraid to pull forward and try again.
