  New Posts New Posts RSS Feed: LifePo4
LifePo4
 Post Reply Post Reply Page  <1234 5>
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Topic: LifePo4
    Posted: 09 May 2023 at 6:07am
I feel the same way. What model did you get?
LB Boozer View Drop Down
Post Options Post Options   Quote LB Boozer Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2023 at 10:23pm
Thanks,  I’ll think I’ll try that for this trip and then address this when I get back.  We just sold the R-Pod and have also moved on to a Grey Wolf like yourself.  We already miss the pod and it has only been gone a few hours, but looking forward to the additional space and utility of the new trailer.
We had the pod dialed in and it’s going to take some time to get the Grey Wolf exactly how we want it.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 11:37pm
It should not affect anything else. The trailer battery will work the emergency disconnect. Your solar should be sufficient as you say. For those of us who don't live in places with abundant sunshine, having the ability to charge while driving is important, especially if one goes to places where one can only run generators for very limited hours.
Post Options Post Options   Quote LB Boozer Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 11:18pm
I don’t really care about charging from the vehicle on this trip.  I will have a generator and I’m in the southwest so the 190w of solar should be able to keep up with the fridge draw throughout the day.  Just want to make sure I don’t damage my alternator or anything else.  When I get back I will install a dedicated line from the truck and a dc-dc charger.
My alternator is 230 amps and the battery make charge.  With the power wire going back to the trailer being so small I wonder how much it could possible draw.
Would pulling the 30amp fuse on the trailer power lead in the tow vehicle affect anything else besides not supplying power to the battery?
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 10:13pm
A lot depends on the vehicle. With the Nissan Frontier, using the 7-way meant that the trailer battery was being discharged while driving instead of being charged. I had to run a dedicated power circuit to a DC to DC charger in order to charge the battery while driving. I have not been able to test whether the Ford F-150 behaves similarly. I already ran the dedicated charging circuit in the truck but have not had the chance to hook it up. I will do that before leaving on any long trips.
hank*pod View Drop Down
Post Options Post Options   Quote hank*pod Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 7:31pm
Your battery will charge at 14.2 volts or whatever your alternator will provide. It just won't fully charge which requires 14.4 volts.
The real risk is burning out the alternator due to low internal resistance in the battery causing high current demand. The DC-DC converter will limit the current.
Post Options Post Options   Quote LB Boozer Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 3:05pm
Thanks.  We are picking up our new trailer Thursday and it is compatible with LI batteries, I was just concerned with the battery draining during transit when connected to the 7-pin.  I tested my truck and believe it is not a “smart” alternator but need to confirm with Dodge this week.  I will eventually run a dedicated run with a DC-DC charger but we already had a trip planned before we pulled the trigger on the new trailer and I only have a few evenings to swap the batteries, go through and check/tighten all the plumbing and electrical and pack it for the trip, so not sure I want to ad that to the list before we leave.
EchoGale View Drop Down
Post Options Post Options   Quote EchoGale Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 11:12am
For my set-up I was able to just switch out the batteries but I have a newer camper with a controller capable of recognizing the battery type automatically.
Julie
Post Options Post Options   Quote LB Boozer Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 11:25pm
Originally posted by EchoGale
One more update: I've been traveling for ten days without access to electrical hookup. I couldn't be happier with my new batter set up. I went with the Renogy 100AH despite the price.
One at the higher price was fine (I needed batteries so I was going to spend 2-300 anyway so 475 wasn't much more)-- but I was afraid I'd decide to add a second and that would have been too much.
As it turns out the new camper's rooftop solar panels easily top off the daily usage (which is only about 15%)--even on this stretch of rainy days we've had on the east coast. I definitely don't need a second battery.
Such an upgrade from my old system: 2 golf cart batteries (heavy!) where I was always pulling to boxes apart to chef the charge level and hauling around my heavy portable solar panel to keep them charged up...not to mention maintenance.
It's a sweet setup. Thanks again for the advice while I was figuring it out.  :)
Did you install a DC to DC charger or just drop the battery in place of the LA battery without other modifications?
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 8:09pm
Congratulations on a successful installation Julie! I am happy that it is working well for you.
