R-Pod 180 outriggers |
GlenHarding ![]() Newbie ![]() Joined: 23 Apr 2023 Location: Doaktown NB Online Status: Offline Posts: 4 |
![]() ![]() ![]() ![]() Posted: 25 Apr 2023 at 12:11pm |
Hi. I noticed that the floor under the slide has dropped about 1/4 of an inch. Contacted Forest River and they sent me 4 outriggers. I tried to follow John Marucci directions. The problem is that when I jacked the side wall up it would not move. I stopped jacking when the tire was off the ground. So at this point what is my next step?
Thanks in advance. Glen
Glen Harding
2020 Jeep JLU R-Pod 180 |
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2707 |
Hope that time will help. jack up the sidewall and leave it there for a day or two or three to see if it will deform back to something closer to "normal".
HI. Thanks for the idea.
Glen Harding
Vernsburns ![]() Newbie ![]() Joined: 20 May 2023 Location: Michigan Online Status: Offline Posts: 2 |
Glen, I am having the same issue you described. I followed John M’s video and the Jack lifted the whole trailer. Seems like the floor is bent, not sagging. A quarter inch or more at the bump out. Can you post if you find a solution? I’m perplexed…
Hi. Hopes this helps. I contacted Forest River and after about a week they replied.
They asked for several pictures, some measurements and other info. They emailed me back the same day to tell me that I needed a new axle and that my local dealer will fix the floor sag at the same time. It seems that I have an over torsion axle. I contacted my dealer who is 180 miles away. The only one in my province. The dealer was aware of the problem but wanted to inspect before committing to the repair. Forest said that if the sag was less than an inch then a dealer can do the repair. Over an inch then the unit has to go to the factory. They were concerned that I installed out riggers. After they realized that they provided them, the concern vanished. Forest also said that it would be no problem to wait till fall or winter to get the repair . All in all I was very pleased at how Forest River handled this.
Glen Harding
Thanks for the update! I will contact Forest River. We purchased our 179 used so I hope that isn’t an issue.
2016 179
2019 Chevy Colorado |
Good luck. Let me know how things go?
Glen Harding
