  New Posts New Posts RSS Feed: LifePo4
LifePo4
EchoGale View Drop Down
Post Options Post Options   Quote EchoGale Quote  Post ReplyReply Direct Link To This Post Topic: LifePo4
    Posted: 21 Mar 2023 at 10:32am
That's a helpful article  :)
I wasn't that worried and was mostly teasing you.
Julie
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 10:28am
Originally posted by StephenH
I think one reason is that it is hard to control the external environment. LiFePO4 batteries do not like to charge below 32F (0C). For a battery to be used in a vehicle, there would need to be a way to warm the battery in freezing environments. Likewise, they don't like getting too hot. I've read enough stories of battery powered vehicles bursting into flame. For the time being, lead-acid batteries are still safer for use as starting batteries. That may change as newer battery technologies become available.
LFP batteries do not have the fire risk of the various "Lithium Ion" batteries. From all the things I've read, they appear to be as safe as lead acid.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 8:36pm
I don't think you have to worry. LiFePO4 batteries are much better than Lithium Ion batteries used in vehicles. I believe the one I bought does have the ability to self-warm. Here are the operating temperatures for the one I am using:
Charge 0C-50C (32F-122F)
Discharge -20C-60C (04F-140F)
Storage -10C-50C (14F-122F)
Unless you are camping in Death Valley in the summer, I don't think you will have a problem with heat. As for cold weather use, you can mount it inside since it doesn't put off fumes. Given that these cost a lot, having it inside is also better protection against theft. Mine is inside of a locked metal Harbor Freight tongue box that is U-bolted to the A frame. I do have some foam padding for insulation. I have had no problem with using it when it was inside under the bed in our RP-179.
This site has a good comparison and may help ease your mind.
Post Options Post Options   Quote EchoGale Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 6:14pm
Thanks for the new  round of comments. The BMS in one of these lower prices off-brand batteries comes with the ability to warm itself and that is of great interest to me because I do camp in temps between the low 20s and freezing. How worried do I need to be  about my whole camper bursting into flames???? (STEPHEN!!!!)
Julie
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 1:18pm
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 11:11am
It would be nice if vehicle batteries started coming with LFP batteries.
Secondarily, it would be nice if vehicles cam with 48V battery systems. I know Tesla is switching to 48V for all internal systems (separate from the motors). This may become a trend because it allows you to eliminate a lot of copper (which weighs a lot).
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2023 at 5:11pm
If your trailer is new, you may have an auto-sensing converter that can handle the LiFePO4 battery. You would need to verify that. I have a WFCO WF8950L2 MBA that I was using and I removed it when I traded the RPod. I don't need it for the new trailer so it is available.
What is questionable is the ability of the vehicle to charge the battery. Newer vehicles use a "smart" alternator charging circuit. The higher voltage of the LiFePO4 battery makes the alternator think the vehicle's start battery is charged, so it loafs, drawing power from your house (trailer) battery. You may find you start with a fully charged house battery and arrive with it significantly lower. For that, you need to use a DC to DC charger. I was using the Renogy 20A DC to DC charger with the RPod. I won't need it with the Grey Wolf because I am going to be installing a Renogy MPPT charge controller with dual input. That handles the DC to DC charging from the vehicle as well as the solar from the panels. I have not decided what to do with the DC to DC charger yet.
KenWP View Drop Down
Post Options Post Options   Quote KenWP Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2023 at 4:36pm
I just installed two of these inside the forward 'electrical cabinet' of my '17 177HRE.
https://www.amazon.com/dp/B09F2LLMY3
I also got the upgraded / updated converter to properly manage the charging:
https://www.amazon.com/dp/B0B46SCH3T
First trip with this setup will be 2-3 night boondocking this coming weekend. I'll report back if any issues.
Colt View Drop Down
Post Options Post Options   Quote Colt Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2023 at 3:38pm
Hi Miss Julie,
I have 2 of these Eco-Worthy 100 A-Hr batteries, in parallel, in my home system and one is likely destined for my R-pod.  One of these has about the same usable A-Hrs and my previous Pb-SO4 bank and is so much simpler.  I have been well satisfied with everything I've gotten from Eco-worthy, so far.  Though pretty new, I expect the batteries to be the same.
https://www.amazon.com/dp/B09L89LW3P?psc=1&ref=ppx_yo2ov_dt_b_product_details
Most likely the "have its own computer" statement meant a BMS and all of the Li batteries in retail have the BMS built in.
Your original converter will be adequate for a LiFePO4 battery, but you may want to upgrade sometime to a converter with Li capability.
John
'16 R-Pod 180
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2023 at 6:36pm
1. In specifications, yes. The higher priced ones are likely to have better BMS systems and/or the ability to warm themselves when they are cold so they can accept a charge. There may be a longer warranty as well. The batteries used may be constructed differently. In the case of the Expert Power battery, their claim is to a better quality battery.
2, I think by cheap ones, he may have been referring to one without a BMS. Just about any of them you see on Amazon will have a BMS. You can purchase cells and put them together into a battery for pretty cheap, but it will not have the BMS. You can add that and then you are getting into the price range of a complete one with BMS from what I have seen.
3. Yes. The instructions are confusing. Install and run appliances until it shuts down is one way. On the other hand, installing it and charging it is likely to work just as well. The part about connecting a solar panel without the controller had to do with activating the BMS if the battery had been discharged down to where the BMS went into protective mode. Since it is partially charged, the BMS should not be triggered that way, so regular charging with the converter or with a solar panel through the controller should be just fine. I am guessing that your converter is suited for Lithium batteries. Mine came with a sticker saying it would auto-detect the type battery, so I did not have to change anything with the new Grey Wolf when I removed the L-A battery and installed my LiFePO4 battery. Please confirm though whether the converter is suitable for Lithium batteries.
