  New Posts New Posts RSS Feed: battery disconnect switch
Colt View Drop Down
Post Options Post Options   Quote Colt Quote  Post ReplyReply Direct Link To This Post Topic: battery disconnect switch
    Posted: 26 Feb 2023 at 8:57pm
Mine was and I reinstalled the replacement in the positive lead.
John
'16 R-Pod 180
Tars Tarkas View Drop Down
Post Options Post Options   Quote Tars Tarkas Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2023 at 9:13pm
Originally posted by Rpod-Couple
Forest River puts their disconnect on the positive terminal. Your 12Vdc fuses in the breaker panel are on the 12V positive terminal.
This is also consistent with your home breaker panel main breaker and branch breakers which disconnect the AC hot line but leaves neutral/ground always connected.
I didn't know FR did battery disconnects, but of course the fuses/breakers are on the positive side.  The negative is provided through the frame.
And AC and DC are apples and oranges in this discussion.
Rpod-Couple View Drop Down
Post Options Post Options   Quote Rpod-Couple Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2023 at 7:08pm
Steve & Elaine
2021 R-pod
2023 VW Atlas Cross Sport
Post Options Post Options   Quote Tars Tarkas Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2023 at 2:46pm
Originally posted by GlueGuy
The entire frame of the trailer is negative, so I would be inclined to disconnect the positive. It may not make too much difference, but I'm happy to hear other opinions.
The frame is only negative when it's electrically connected to the negative side of the battery.
I've heard different things too about which way to go.  Traditionally, I think disconnecting the negative side is the story.  I believe NASCAR calls for the positive, but I'm not sure.  I leave my pod hooked up to 120v at home and don't use a switch.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2023 at 2:19pm
Interesting topic.  I am old school and simply take my 1/2" wrench to disconnect the ground, takes maybe 15 seconds but that is probably 14 seconds longer than having a simple disconnect switch.
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2023 at 11:08am
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2023 at 10:08am
Yes.
Seriously, I was taught to disconnect negative first and connect it last. However, I have read good reasons for having it on the positive side, so that is where mine is.
john in idaho View Drop Down
Post Options Post Options   Quote john in idaho Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2023 at 9:15am
finally got a battery disconnect switch.  for what may be a really stupid question, is it important that it go on the neg pole of the battery, or the pos?  Embarrassed
