Nitrogen Dioxide |
Page <1 2345> |
![]() ![]() ![]() ![]() Posted: 13 Jan 2023 at 10:12am |
It's a high efficiency Mitsubishi. It brought the room up to a very comfortable 68°F quickly and quietly. When I get the next Eversource bill, we'll see how it does compared to the radiant oil electric unit.
As for the leasing of equipment, between Eversource and the leasing company, the economic benefit left over for the consumer is negligible, hardly worth the bother. The big companies always make sure they get the pig's portion of the benefit.
EchoGale ![]() Senior Member ![]() Joined: 10 Mar 2019 Location: FL Online Status: Offline Posts: 469 |
I have a question about these studies that has bothered me for a while and i bet one of you will have an answer. I can never tell what kind of "gas" they're using in the studies and suspect it's mostly "natural gas" not propane. I use propane in both my house and, obvs, my camper. Are the problems the same with both kinds of "gas?"
Julie
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3349 |
Well said, fortunately we have a seemingly endless supply of wood in northern Michigan and thanks to the EAB, a lot of white ash trees are dead, but still standing, allowing it to 'cure' for instant burning once it is cut, carried off, dumped off trailer, split, stacked, unstacked and brought to the stove, and finally burned. Also a lot of other wood as well, maple, beech, ironwood, birch, that oft times may be laying on the ground and at certain points of decomposition so those have to be cut up first before they become one with the earth again. Regardless, kudos for you in using wood, a great way to keep away from doctors, hospitals, ect. and keeping your body 'fit.'
Yep, and if you burn standing dead wood (as opposed to what were living trees) youre not contributing to global warming because as you say the wood was going to decompose anyway. Decomposition is just slow burning, so it puts the CO2 the tree absorbed right back in the atmosphere. Wood burning is not a solution in urban areas though because of particulate pollution. But out in the boonies it's fine.
EchoGale, the NO2 is a product of combustion. the nitrogen isnt in the fuel, it's in the air, so a little of it gets oxidized to form NO2 when you burn pretty much any fuel. NO2 from burning gasoline is what used to form all that nasty brown LA smog back before cars got good pollution controls. And BTW it's formed from burning wood too. The difference is that only a cook stove or unvented space heater throws the stuff right into the house rather than outdoors.
In the old days, gas stoves used to have the ovens vented to outside. Then they stopped doing it in the late 50's or so. I wonder why the stove manufacturers and building codes switched?
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6433 |
You didn't grow up around here. There were unvented gas stoves in many places. The flame would be at the base of a flat ceramic textured plate. The flame would heat it to glowing. The radiant heat off of that heated the room. That was before oxygen depletion sensors, but also before houses started to be built with vapor barriers and gaskets that sealed them up so there were always ways for fresh air to get in and fumes to get out.
I am glad you brought this point up. I am not trying to be 'religious' or 'political' here as the beauty of this book is that the majority of this book is a compilation of historical written documents written by the original authors. He gives thanks to the Librarians of the Young Men's Mercantile Library Association, the Mechanics' Institute Libraries of Cincinnati, the State Library of Ohio, the Historical and Astor Libraries of New York, the Mercantile Library and Library Association of Philadelphia, the Libraries of Congress, and of the Interior Department and Chief Clerk in the Department of State. What Morris did here was take numerous written and recorded documents (many found in the Library of Congress), many times without comment and put them together in a readable form.
gpokluda ![]() Senior Member ![]() ![]() Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 399 |
Great point, StephenH. As I read through this thread, I was thinking how things were when I grew up in the 60's and 70's. We had a gas stove and the pilot lights were always on as was the oven pilot and the one for the griddle. That's how we used to defrost meat, or anything else, before the microwave became a household appliance. We would set whatever it was to be defrosted in the cast iron dutch oven and set it on top of a burner in the morning. It would be defrosted in time to make dinner. No respiratory issues with any of my 5 siblings but of course our house was somewhat drafty, so that probably helped.
FWIW, we also drank out of garden hoses, road bikes without helmets, played with lawn darts, and rode in the back of pickups. It's amazing we even survived
Gpokluda
StephenH, I grew up in the far west and when I worked for a remodeling contractor in San Francisco, we were always contending with the vent pipes for the ovens of stoves. Even the radiant ceramic heaters and regular space were vented. But, there was certainly a lot of air coming in through leaky doors and windows providing, as you observe, good air exchange. Now with the houses we're building here in the Habitat project in CT, they're about as airtight as one can get. They are built to the new air leakage code: C402.t (Air Leakage) of the 2021 International Energy Conservation Code. (IECC). A positive air pressure test must be passed that is so tight combustion products could well become a problem without adequate venting.
Jato, I respect the strength and sincerity of your beliefs, but you just made my point. Mr. Morris gave us his interpretation of the sources he consulted from libraries. All are his opinions about what was in the mind of other people based upon his interpretation of what others had written about what the they thought were the intentions of the founding fathers. In the legal business, we call that hearsay and speculation and it is not admissible evidence to prove a fact. Probably some of the people who were involved in founding of our country shared your and Mr. Morris' views, but there were many who did not. Many of the founders were aghast at the idea of any religion whatsoever being involved in any form in our governance. We can cherry pick the evidence of the original writings of the "founders" and claim it supports any position we may advocate, but it would still only be our opinions. I am not aware of one single actual "founder" who specifically wrote that his or her intent was x in writing some clause in the constitution. And even if there was, it would prove nothing in regard to the intent of the other writers or founders, whomever they may be. We can glean what we please from their writings, but there is simply no reliable first had evidence that all, or most, of the founders specifically agreed as you opine. I think we have beaten this dead horse of religion and politics to death. It is really a violation of the rules of the board in which we agree not to discuss religion or politics.
Also having grown up in California, my experience was the same as LA's. Gas ovens and space heaters were vented. Only the stove burners weren't.
And no central heat. I well recall standing on top of the gas floor heaters in my parent's house trying to get warm on a chilly morning. And yes, NorCal can get pretty chilly at night in the winter. Uninsulated walls and single pane glass. We didn't have enough money to run the floor heaters at night so it was pretty common to see condensation from my breath when I woke up in the morning. That's what warm blankets were for. But nothing compared to what my mom who grew up in the UP in the 20s and 30s had to deal with. Outhouse at 40 below....
First World problems. No one worries about NO2 in their house when it's all they can do to not freeze to death. |
Page <1 2345> |
