 Post Reply Post Reply Page  <1 565758
Geezerbill View Drop Down
Post Options Post Options   Quote Geezerbill Quote  Post ReplyReply Direct Link To This Post Topic: ouR escaPOD mods
    Posted: 06 Dec 2022 at 3:33pm
Thanks so much for your water system flushing recipe. I will use it next spring. Next winter I will not add the rv antifreeze to the water lines. My dealer recommended to do so and to run some through the water pump. That made some sense but I think a good complete blowing out should do it…..hopefully.
Bill
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2022 at 5:38pm
Originally posted by Wingo
What type of converter did you use to have your 110 V CPAP machine run on 12V? I would be interested in this mod also.
Since the DreamStation 2 is natively running on 12V, I got a simple (but expensive) 12V plug and installed a 12V outlet to plug it into. If you have a CPAP machine that runs on 24V, then you would need a boost converter to boost the 12V to 24V or an inverter to use your AC power block. So, it isn't a simple answer. It depends on what you have.
We will have an issue in the future. My wife just started using oxygen at night. We will need to figure out how to power an oxygen concentrator. That will likely be a modification to come.
Post Options Post Options   Quote Geezerbill Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2022 at 8:41pm
Stephen,
Great idea on the Jack pads you made. When the weather cooperates, would it be possible to show a picture or two of the placement of the jacking pad in position to lift the trailer. I am confused as it relates to lifting the trailer. Dimensions of the block would also be most appreciated.
My 192 was purchased last July and after driving it home 180 miles I noticed the tread seemed worn down significantly. How could that be. Maybe not new. Hum. After 800 miles of use this past summer I am most disappointed with the Goodyear Endurance tire and likely also purchase the Carlisle tires next summer.
Thanks in advance for your reply.
Bill
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2022 at 10:00pm
Placement is easy. It goes where the axle attaches to the risers or frame so that the V notch cradles the axle and the flat parts support the vertical plates that attach the axle to the trailer. Your 192 may be set up differently. You will need to customize to suit your trailer. The V notch is so that the jack pressure is not on the axle tube. I used scrap lumber for this. Dimensions are what you have vs. what you need.
As for the tires, get them balanced if they were not done so already. Also, check that there is not excessive camber (tires leaning in or out). Also, check the inflation to make sure it is up to specification for your tires. The wear pattern will help you diagnose what is happening. If the wear is in the middle but the edges are okay, then it might be overinflated. If it is on both edges, but the center is okay, it might be underinflated. If the wear is on the inside or outside edge, but the rest is okay, then look at the camber. If it is scalloped, then have the tires balanced and/or check the brakes for drag. If the brakes lock up, it will put a flat spot on the tire. Last, check the bearings in the hubs. If they are too loose, the wheel and tire may be moving in ways that they are not supposed to .
Also, do a search of the forum. Advanced search is your friend. With it, you can search older posts. The default is to only search those newer than 6 months. With advanced search, you can search any date and be more likely to find help.
Post Options Post Options   Quote Geezerbill Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2022 at 10:57pm
Thanks so much Stephen. When I noted the tread wear after the drive home from the dealer I checked the air pressure and found them to be 20 lbs under spec so I inflated them up good. Still will need new tires shortly after summer begins. Thank you for the tire tips and the jacking information. Next spring I will make two of your blocks.
Kindest regards, Bill
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2023 at 7:37pm
Originally posted by DavMar
Originally posted by StephenH
I think I will skip that for now. I am studying to take a Technician Class Amateur Radio License exam this coming Saturday. That is priority for right now.
Stephen, I know this is totally off the subject (so please everyone forgive me) but who in your area is doing examinations now??? I know my club FARC, Forsyth Amateur Radio Club out of Winston Salem is no longer testing due to the Covid 19 virus along with all the other radio clubs in the surrounding counties. Good luck on the test, its pretty easy with mostly just rules and regulations, for the technical license. If you ever hear the call sign on air of KN4VBT that's me! I really need to get my extra license so I can get a one by three call sign but without anyone locally giving the test and being so busy repairing vintage radios don't have time now to the little I need to get the license.
I know this is long after the fact, but I don't remember if I answered your question. It is likely moot though since the restrictions have been lifted.
If you look at Chris Cancilla's site, W4CEC.com, you will find out information there. Another is Five County Ham Radio Enthusiasts. Both are Laurel VEC teams and thus do not charge a fee for testing, unlike some of the others.
