  New Posts New Posts RSS Feed: Rainy winter
Rainy winter
Geezerbill View Drop Down
Post Options Post Options   Quote Geezerbill Quote  Post ReplyReply Direct Link To This Post Topic: Rainy winter
    Posted: 02 Nov 2022 at 7:05pm
I have stored my 192, covered, for the winter. I live in rainy western Washington. My questions are:
1. Should two windows be slightly opened or
2. Should I use one of those dehumidifier pots to collect the moisture and dry and reuse the crystals or
3.  Should I do neither?
Thanks for your input!
Bill
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2022 at 9:20pm
I go with windows shut and the large Damp-Rid bucket. That is one that you take the lid off and set it in there and it absorbs the moisture.
Post Options Post Options   Quote Geezerbill Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2022 at 9:22pm
Stephen, thank you! That is what I was considering. Will see if Amazon has them.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2022 at 10:10pm
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2022 at 7:11am
Damp Rid is an excellent product.  I use it during the winter months in northern Michigan in the storage area on a 177.  Have never had the need to put inside the pod, but for some reason the storage area tends to get a bit of a musty smell over the 5 months it is stored if I don't use the damp rid.
hank*pod View Drop Down
Post Options Post Options   Quote hank*pod Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2022 at 8:03am
Originally posted by StephenH
If not, your local Lowe's or Home Depot should have them.
For what it's worth I got a pack of six 11-ounce mini buckets of Damp-Rid at BJ's a couple of weeks ago for about $18. I figured I'd stick two at a time in there and check on them every couple of weeks. The TT is being stored offsite so I'll need to check on it periodically anyway.
