  New Posts New Posts RSS Feed: Fridge on when driving??
Ben Herman View Drop Down
Post Options Post Options   Quote Ben Herman Quote  Post ReplyReply Direct Link To This Post Topic: Fridge on when driving??
    Posted: 13 Oct 2022 at 9:50pm
Like the others have said, I run my fridge almost exclusively on propane. Its very efficient and works well. Not so on 12v power, it runs the battery down quickly. So when I unplug from shore power, I always switch it to propane and let it run that way when travelling.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2022 at 6:46pm
+1 to Stephen H.  We have operated our Dometic fridge on propane for 12 years now on our 177.  Have traveled over 43,000 miles and no issues.  In fact the only time it isn't on propane are the few times when we find a campsite that offers electric.
Also check your onboard battery (12v) or batteries (if you have a pair of 6v).  The motherboard needs 12v power to function correctly.  If your battery is low (below 12.1v or thereabout) it will cause the beeping.  Hopefully you have a multitestor or voltmeter.  Fully charged at rest the reading will be 12.72 volts, if at 50% (you want to charge your battery if it gets to this point) 12.2v.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2022 at 4:25pm
Use of propane while traveling isn't necessarily dangerous. Before our refrigerator died and I replaced it with an AC/DC model, I used propane while driving with no issues. I did put bug screens on the vents to keep wasps from building nests in the burner area (had that happen when we first bought the RPod). As to why it is beeping, you might wish to check to see if your refrigerator is operating on propane or battery. The beeping could be low battery or it could be that the flame failed to light. Do you have the propane turned on or off when you are on the road?
paulpiastro View Drop Down
Post Options Post Options   Quote paulpiastro Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2022 at 2:27pm
A dumb question-when the fridge in my rPod 192 is turned to "auto" and I unplug from shore power, does it switch to battery or gas while driving?? I would assume using the gas would be dangerous---I get a continuous beep when I travel however the food seems to stay cold in the fridge--can someone explain this??  Thank you.
