Front door won't close |
176turbodiesel
Newbie Joined: 09 Jul 2017 Location: NY Online Status: Offline Posts: 15 |
Topic: Front door won't close Posted: 09 Oct 2022 at 10:58am |
Hey All
My front door is sagging down and won't close. I'm nervous about reinstalling the door as there's such little clearance in the walls. Has anyone solved this problem? |
Dirt Sifter
Senior Member Joined: 30 Dec 2018 Location: Right side OR Online Status: Offline Posts: 170 |
Post Options Quote Reply Posted: 09 Oct 2022 at 12:47pm |
Hey, Turbo, there are a lot of Rpods on the market. Which year and model to do you have?
Greg n Deb 2020 195 HRE
'07 Tundra 5.7L., '17 Tacoma 3.5L. Both with tow packages 1 Puggle, 1 Chihuahua support staff |
gpokluda
Senior Member Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 280 |
Post Options Quote Reply Posted: 09 Oct 2022 at 5:40pm |
Hi Turbo. Sorry to hear about your door. First make sure the friction hinge is properly lubed. Folks use all kinds of lubes but it wouldn't hurt to just give it a shot of WD-40 first. Even though it is a friction hinge, it does have to move somewhat freely. If the hinge is too stiff, the light weight door frame will twist and it will appear your door may be sagging or twisted. Also, make sure the door latch and lock box screws are nice and tight. They do tend to loosen up frequently. I'd start there first.
Good luck.
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Triumph T120 |
176turbodiesel
Post Options Quote Reply Posted: 10 Oct 2022 at 8:16am |
2018 176t the one with the flop out
mjlrpod
Post Options Quote Reply Posted: 10 Oct 2022 at 4:47pm |
Hopefully you don't have to much pressure on the stabiler jacks? Lifting up both ends, curling it like a potato chip.
