water pump - Event Date: 07 Oct 2022 |
Page <123> |
![]() ![]() ![]() ![]() Posted: 09 Oct 2022 at 12:24pm |
Sounds like you may need a new pump. I suppose you could take it out and test it just to be sure, but it looks like you have pretty much eliminated the other possibilities.
Dirt Sifter ![]() Senior Member ![]() ![]() Joined: 30 Dec 2018 Location: Right side OR Online Status: Offline Posts: 170 |
I had a small crack in the plastic crown on top of the pump that let air nix the suction. Replaced it and all worked well. Looking at the crack it looked more like a scratch. Good luck with your issue.
Greg n Deb 2020 195 HRE
'07 Tundra 5.7L., '17 Tacoma 3.5L. Both with tow packages 1 Puggle, 1 Chihuahua support staff |
hogone ![]() Senior Member ![]() ![]() Joined: 09 Apr 2013 Location: High Ridge, MO Online Status: Offline Posts: 1060 |
I actually noticed that dirt sifter this morn.......not a crack but what semed to be a slight separation at seem (maybe thats what you mean)..........pump time......looks like 80 bucks. jpp
Jon & Pam
2013 RP177 2023 F150 2017 HD Streetglide CHEESEHEAD |
Not sure what you mean but if there is any air getting in due to a crack or a separation in/at the filter bowl, the pump is going to pump air, not water. New bowls are easy to find on Amazon. They come with a screen and a gasket. Real easy if that's what it is. TT
FJ Cruiser |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6431 |
And, if needed, you can get a complete filter for not much more than just the strainer bowl.
sorry if I mispoke. not at the bowl, bit where the pump is bolted/screwed together in the mid section. will keep troubleshooting tomorrow. jpp
Jon & Pam
Could have had a little water left in it which froze up last winter, since you havent been using it. Probably it's toast, but it wouldn't hurt to take the pump apart, clean everything up and inspect,
then if you like what you see put it back together and bench test it with a suction line and a water jug. . Sometimes you get lucky, and at worst you learn something for the next time someone has a problem.
Even if you use air to winterize, it is good to run the pump for a little after draining the tank to empty any remaining water out of the pump if you are not going to be using the winterizing valve to pump RV antifreeze through the system.
Yup, looks like I will yank the pump. Just to clarify everything, I thoroughly winterized everything last fall with rv antifreeze as I have been for 10+ years. This spring dewinterized the entire system and everything worked wonderfully. A few days ago when I decided to drain everything just to rinse everything out (and I actually ran the pump prior to and it worked fine). When I say drain everthing, I mean fresh water tank, hot water heater, low point drains, etc. When I refilled fresh tank to fill hot water tank and fill lines, the pump would not prime as usual. Prob just a coincidence of the pump malfunction. Thanks all for your input. jpp
Jon & Pam
If the motor is spinning.. a new "head" can be had on the big A.. Like $17 last time I looked. 9 screws and it's changed, pay attention to screw length, they are not all the same.
Page <123> |
