  New Posts New Posts RSS Feed: Torsion Axle
Torsion Axle
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Topic: Torsion Axle
    Posted: 09 Aug 2022 at 2:40pm
While rpods aren't made for rough or off road use I found I could get pretty much anywhere I wanted to go as long as I went really slow.
It's high g forces that will bend things, and high g's come from hitting potholes or bumps hard. So speed is the enemy. Just roll through really slowly, crawling speed, and you should be ok. Might take an hour or more to go the 3 miles but what's the rush?
JimBinOC View Drop Down
Post Options Post Options   Quote JimBinOC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2022 at 1:37pm
Thanks for the informative responses. I will check camber and remeasure the crown. I will also look into reinforcing the axle. We have to tow this trailer over 3 miles of dirt ranch road to get to our vacation spot so like I said before, it's had a hard life and gets used often.
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2022 at 5:50pm
Yes, about 3/16 is right, but not the 4 ft distance. Run a string line from end to end of the bottom of the axle tube and measure the gap in the center.
As StephenH suggests, the more important measurement is the camber angle of the wheels themselves.
If you are concerned about the axle getting bent (and you should be, it's not uncommon) you can reinforce it. I have a series of posts on how to do this (as do several others with various methods) You can use the advanced search and go back a few years to find it.
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2022 at 10:21am
The easy way to tell if your axle is un-bent (so to speak) is to check to see if there is any outward cant to the plumb of the wheels & tires. The wheels & tires should be vertical to the ground. If they are inclined inward at the top, then you axle may have lost some of its curve.
I don't recall what the amount of bend is there by default. 3/16 or 1/4 inch sounds about what I remember, but I'm sure someone else will chime in.
Post Options Post Options   Quote JimBinOC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2022 at 4:48pm
I have a concern about our torsion axle on a 2017 179. I seem to remember that these axle housings are supposed to have a slight arch (crown?) to them. My question is how much? Ours seems to have about 3/16" over the length of a 4 ft. level. I'm concerned ours might be sprung since it's had a hard life.
