  New Posts New Posts RSS Feed: RP 179  2018
RP 179 2018
HillbillyMedic View Drop Down
Post Options Post Options   Quote HillbillyMedic Quote  Post ReplyReply Direct Link To This Post Topic: RP 179 2018
    Posted: 24 Jul 2022 at 2:30pm
MY refrigerator doesn't work.  When on 120V the plug icon, the level lights and the red light all just flash. On battery it doesn't flash, but it doesn't work either.
All fuses and breakers are ok.
Be careful.
RoverPod View Drop Down
Post Options Post Options   Quote RoverPod Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2022 at 3:34pm
What's your battery level?
2017 F150 XLT SuperCab
2020 rPod 180
Post Options Post Options   Quote HillbillyMedic Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2022 at 3:47pm
Won't work on 120V.  Battery should be fine.  Been on shore line past two weeks.
Be careful.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2022 at 4:07pm
Battery "should be fine" does not answer the question. You need to verify the battery level.
Does it work on propane? Have you checked your ground fault interrupter outlet? The breaker might not be tripped, but if the GFI outlet is tripped, it would keep the refrigerator from getting 120V power.
Post Options Post Options   Quote HillbillyMedic Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2022 at 5:54pm
Well, the battery powers everything when the shoreline is disconnected and it doesn't work on 110 with all the receptacles working.  Not interested in running it on propane.
Be careful.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2022 at 7:15pm
Have you verified that the 110V receptacles are all operating (plugging something like a light into them or using a multimeter to check them)? As I said, if the GCFI is tripped, the refrigerator will not get 110V power, even if the breaker in the panel is not tripped.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2022 at 9:06pm
+1  To check that outlet, (the one the fridge plugs into) plug in a drill or lamp and see if it will operate.
