  New Posts New Posts RSS Feed: Battery losing charge quickly
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Topic: Battery losing charge quickly
    Posted: 18 Jul 2022 at 3:18pm
If you arent getting your battery fully charged at home for long periods, it could be damaged now. What happens is the lead battery plates become covered with lead sulphate and can no longer pass current. You can go a few weeks like that but longer than that you should find a way to float charge the battery. If you don't want to run an extension cord out to the trailer for a couple of days once in awhile, or put in an outdoor receptacle, you can maintain battery charge with a small solar module if you have direct sun available. If not the you can remove the battery and put it in the garage on a charger.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2022 at 9:28am
How long was the trailer unplugged? As Vann wrote, the tv antenna switch, if left on, can be a power draw. It is best to disconnect (using a battery cut-off switch or removing the negative cable) if not connected to a source of power to maintain the battery/batteries.
Pod People View Drop Down
Post Options Post Options   Quote Pod People Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2022 at 9:22am
One other parasitic draw that has not been mentioned is the television antenna power switch. Make sure that switch is turned off.
travel safe and often
Vann
Vann & Laura 2015 RPod 179
Geezerbill View Drop Down
Post Options Post Options   Quote Geezerbill Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2022 at 7:44pm
Thank you for your response! Actually, back in the day we dry camped with our 22’ Timberline trailer for ten days, using two group 24 Interstate batteries without going dead. We just don’t use anything other than water pump and one led light at a time. So it’s somewhat baffling. I will be going again in late August so I will see how that goes although it’s only for three days and I will have a second battery installed then. Hopefully tomorrow or Tuesday I will post two new issues with my R-pod and look forward to yours and others expert opinions. Thanks again.
Bill
billyingolden View Drop Down
Post Options Post Options   Quote billyingolden Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2022 at 6:47pm
Thanks! When the issue has occurred, everything has been off, no TV connected, etc. It's literally just sitting there. Fridge off, breakaway cable plugged in properly, and thermostat entirely off.
Unfortunately we can't keep it plugged in because we don't have an exterior plug and don't want to put the cord under our garage door.
But it has been trivial to just disconnect it when it's sitting at home for more than a day and hook it back up when we're ready to go out again, so I feel like we've solved the acute problem. I'll likely add a disconnect switch just to entirely remove that step and just make it the flip of the switch.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2022 at 6:38pm
Originally posted by billyingolden
Just coming back to this, I did indeed manage to kill the battery by discharging it too much initially. We got a new battery, and I now unhook the battery and have a small trickle charger that it's hooked up to periodically when the trailer is in our driveway. It does seem like a bananas amount of parasitic load, which I haven't been able to nail down, but the combo of unhooking the battery when not in use for more than a day + getting the Renogy solar suitcase has been the trick, and things have been smooth since. Thanks everyone for the thoughts and advice.
If you keep the trailer plugged in, the converter will keep the battery charged without requiring a separate trickle charger.
I recommend getting a clamp-on AC/DC voltmeter/ammeter. It will help you to isolate what is causing the draw and how much it is. Clamp it around one of the battery cables (I'm not sure if it matters if you use the positive or negative cable). Look at the reading. Pull fuses in the panel one by one to see what changes. If you have a high reading and pulling a fuse causes it to drop significantly, then investigate that to see why it is causing a high draw.
Suspects are the refrigerator being operated on DC, the breakaway cable for the brakes being pulled (or defective), or heavy furnace use. Other things like your vent fan draw power, but not as much as the first three. Another thing might be if you are sitting with the tow vehicle connected, power might be feeding back to the tow vehicle from the trailer. If you have a weak battery in your tow vehicle, it may be taking power from the trailer battery. That should provide a starting point for figuring out why your battery is draining quickly.
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2022 at 6:22pm
If the tech was just testing the brakes for a few minutes total then there shouldn't be any lasting negative effects from pulling the breakaway pin. IIRC the brake magnets take around 10 amps each when engaged so that's 20 amps for two. If the tech energized them for say 10 minutes testing then that would draw about 20 x 10 / 60 = 3.3 amp hours, or only about 3% of a typical Rpod battery capacity. Not a big deal.
I wonder if you might have some other load on the battery that youre not aware of, or maybe using more power that you might have in the past? Two days capacity doesn't sound terrible, watching a little TV and running the fans or furnace I used to go through about 50-60 amp hours a day, or roughly 2 days for a single battery system.
Post Options Post Options   Quote billyingolden Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2022 at 6:21pm
Post Options Post Options   Quote Geezerbill Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2022 at 6:04pm
Off grid, I am a new member and recently new owner to a RP192. During initial drive my brakes did not work so after four miles I took it back to the dealership. In the trouble shooting process the tech repeatedly pulled the brake away pin to see if the brakes came on.
My question is what negative effect does that have on the battery?
After a 125 mile drive home the next week we went camping for a week. I had charged the batter in my garage for 48 hours and was aghast when it died after 3 1/2 days. We are very experienced at using very little electrical use when dry camping so I feel comfortable about our useage.
This dealer was much less than desirable and I will list other topics related to them in the coming days.
Your opinions along with others on the breakaway/battery drain will be most appreciated. Thank you,
Bill
john in idaho View Drop Down
Post Options Post Options   Quote john in idaho Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2022 at 7:52am
One suggestion, alluded to above, would be to unhook the battery and let it sit for a few days then measure the voltage.  Most auto parts stores will load test a battery but that may not be a valid test for a purely deep cycle battery and the folks who have already commented are more knowledgeable about that.
