  New Posts New Posts RSS Feed: Furnace
Furnace
Robert View Drop Down
Post Options Post Options   Quote Robert Quote  Post ReplyReply Direct Link To This Post Topic: Furnace
    Posted: 25 Jun 2022 at 2:11pm
Will not light.
JR View Drop Down
Post Options Post Options   Quote JR Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 3:00pm
A little more information would be helpful like does the LP gas tank have gas in it and is it turned on, do the other gas appliances work OK, does the dometic thermostat call for heat, is there 12 volt power in the trailer, and has the furnace worked in the past?  Just for some basic information.
Jay
179/2019
Colt View Drop Down
Post Options Post Options   Quote Colt Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 7:20pm
Mine is hard to light after it has set for a while unless I light the stove first and run it for a few seconds to be sure the gas lines are all full.
Do you hear the igniter sparking as it tries to light?
Where are you that is cold enough to get the furnace to come on in June?
John
'16 R-Pod 180
Post Options Post Options   Quote Robert Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2022 at 4:06pm
The gas is fine. The fan is blowing so loud I can't hear if it's trying to ignight or not. I don't think it is.
Post Options Post Options   Quote Robert Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2022 at 4:07pm
Southern Alberta still gets close to freezing at night.
Colt View Drop Down
Post Options Post Options   Quote Colt Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2022 at 9:10pm
Hmmm, I suppose it might.
I can hear mine spark over the fan. Maybe listen outside?
John
'16 R-Pod 180
Post Options Post Options   Quote Robert Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2022 at 9:13pm
I'll try that.
Post Options Post Options   Quote Robert Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2022 at 11:14pm
It appears to be the ignigher.
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2022 at 11:14am
Try cleaning the igniter and adjusting the spark gap B4 replacing it. It just might work, you never know...
Post Options Post Options   Quote Robert Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 9:22am
Replaced the ignighter. All good now. Thanks for the help!
