AC Bolt Failed |
gpokluda ![]() Senior Member ![]() ![]() Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 398 |
![]() ![]() ![]() ![]() Posted: 17 May 2022 at 4:35pm |
Something similar happened on our recent trip. I noticed the airflow shroud hanging down and also notice a bolt dangling out from the vent. When I removed the shroud, I saw that the rear bolt had sheared just above the shoulder and the threaded bushing was loose. I seriously doubt you knocked the threaded bushing out, those are pressed in the overhead unit. I also noticed the two forward bolts were loose with the bolt heads backed out about 1/4". I tightened those up, fortunately the threaded bushing were still intact.
When we got back 3700 miles later, I had more time and tools to apply a better fix. My guess is the front two bolts loosened, putting a shearing force and the back bolt and it failed. Our overhead unit also had two unused threaded bushing in the rear in addition to the one that failed. I made a bracket and applied a fix for the middle rear bolt so now the AC is secured at 5 points, not just 3. I also took the time to seal up every thing a little better with some foil duct tape I had laying around. Hope your repair was successful. |
Gpokluda
OutdoorFam ![]() Newbie ![]() Joined: 04 Apr 2022 Location: Colorado Online Status: Offline Posts: 1 |
I have a 2018 171 Hood River edition with a Dometic AC unit. I recently noticed that the back of my unit was hanging down. I figured out how to take down the airflow box inside and find the singular bolt on the aft of the unit had ruptured. I’m not sure how long it has been like that, but I have never noticed any leaking or evidence of water damage.
The real problem is that while I was trying to remove the internal bracket I managed to knock out the threaded bushings for the two front bolts. I can’t tighten them back up. I think that I might be score to remove them by hand, but I’m not sure what my next move is. I can’t figure out why they would use a press fit bushing. My only guess is so that the bushing fails before your roof if you over tighten them. Any advice is appreciated. |
