  New Posts New Posts RSS Feed: New Member
New Member - Event Date: 25 Apr 2022
pearlhiggy View Drop Down
Post Options Post Options   Quote pearlhiggy Quote  Post ReplyReply Direct Link To This Post Calendar Event: New Member
    Posted: 29 Apr 2022 at 3:59am
I have a Honda Passport.
Also, found out I have to have a curt echo.  Apparently I have electric brakes on the camper?
I have a lot to learn. Wink
The Higgins' Girls,
Pearl, Zoey Marie & Riley Ann
2017 Rpod 179
Post Options Post Options   Quote lostagain Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2022 at 6:30am
If you have an AWD, your towing capacity (5000 lbs) for your trailer gives you a good margin of safety.  If you have only FWD, you are likely to exceed the weight limit for safe towing.  State laws vary regarding brake requirements for trailers, but the 179 is in the class of trailers requiring a braking system in all states.  It has electric brakes which require a brake controller in your Passport.  Your Curt Echo should do fine for that purpose.
One of the things you will need to become familiar with is balancing the weight in your trailer.  Here is a video that illustrates what can happen if you have too much weight aft:  https://www.youtube.com/watch?v=i2fkOVHAC8Q
You may also want to check with your dealer to see if a weight distribution hitch can be used with your Pasport.  It makes the ride much more comfortable and many on the market also serve as anti-sway devices.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2022 at 6:38am
Yes, the trailer has brakes and you do need a brake controller. You don't necessarily need the Curt controller. There are others that will also work. However, I just took a look at information on the Curt Echo, and it looks like it would be the simplest to install and use.
It was nice meeting you. Hopefully, it won't be long before the cooler arrives and the tow package can be installed.
Post Options Post Options   Quote pearlhiggy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2022 at 7:05am
Yes, it was nice meeting you both. Amazing mods to your rig. Trying to remember where you said you got the 2 steps.
The Higgins' Girls,
2017 Rpod 179
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2022 at 9:15am
When we lifted our 177 we opted for the Stromberg-Carlson 2 step off EBay.  That was 5 years ago - price was $249.  Has worked out well.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2022 at 10:04pm
https://smile.amazon.com/Lippert-432682-Double-Manual-Radius/dp/B00JMHHFVE/
This is like the one I installed. I did have to modify it a little by notching out the back for the frame so it would sit back and not have a gap between the door and the step.
