List Your Mods: |
Page <1 23456 78> |
Kahonu37 ![]() Newbie ![]() Joined: 01 Feb 2019 Location: Florida Online Status: Offline Posts: 39 |
![]() ![]() ![]() ![]() Posted: 04 Jun 2022 at 5:16am |
Did you install the FR lift kit or the Lippert Lift kit. Regards M
2018 179
2012 NISSAN XTERRA (retired 12/19) 2019 RAM 1500 WARLOCK (new) A.R.E. V Series Topper WDH Equalizer 600/6000 |
Also, just realize that even with the lift kit, the 179 is not a great one for off-road. Some of the ruts can still drag the stabilizers on the back end. I have experienced this. Also, if you do take that risk, be sure to go very slow over any bumps/dips or you risk bending the frame (also had that happen on this trip).
Boater I want to install risers on my 2018 179 and I have a few questions for you. Are the risers you ordered from FR. The same as the Lippert Risers? Did you order the risers directly or thru a Dealer? Did you install the risers or dealer installed? How long are they? Have you had any issues with them, since the install Regards M
2018 179
Making the bed is an aerobics session in the 179. I get it the best I can and then put the quilt over it.
pearlhiggy ![]() Newbie ![]() ![]() Joined: 25 Apr 2022 Location: Brockport, NY Online Status: Offline Posts: 18 |
How do you get the bed to look so good?
I can't smooth it out like that. Pearl
The Higgins' Girls,
Pearl, Zoey Marie & Riley Ann 2017 Rpod 179 |
Correction to the above hints: The screen is on the intake side of the pump, not the output side. It protects the pump from debris.
Kup-Pod ![]() Senior Member ![]() ![]() Joined: 08 Jun 2017 Location: Guelph, Ontario Online Status: Offline Posts: 153 |
Hello BB,
First of all, you're one of the few fellow "Ontario-ans" that I've see on this forum... welcome! I had a similar problem about 2 years ago. Suddenly, after using the RPod for a couple of years I had no water pressure in my "kitchen" hot water tap... the cold was fine, the showers were fine but just the hot water. I disassembled the kitchen tap / hot water valve and found construction debris in the tap (some remnants of polyethylene film (probably from a bag) and a some plastic shavings (probably from the water tank fabrication)). Once I removed the garbage from the valve I was back in business. I would start with the shower head and back up from there. For instance, if the water is flowing freely from the shower tap, then disassemble the shower portion. if it's not flowing from the tap, then disasesmble the valves, etc, etc. I hope this helps! Please let us know how you make out... posting the solutions helps the rest of us and it let's you celebrate the victory!:-)
2017 RP-178
2021 F150 5.0l "Lead me on a level path" |
Two areas to check: the most obvious is your shower head as there could be debris that has clogged the nozzles, the other is the screen that can unscrewed off the input side of the water pump. That likely has debris or other items lodged in the screen. Take it apart, flush, screw back in and see if the pressure improves at the shower head. |
Have you considered replacing the shower head with an Oxygenics shower head? I think you would find it much better with the stock pump.
Brendanb ![]() Newbie ![]() ![]() Joined: 15 Mar 2021 Location: Ontario Canada Online Status: Offline Posts: 2 |
Has anyone here replaced their water pump with one that will generate more water volume at the shower head. The stock pump will only create a trickle from it. The other fixtures are fine. Maybe something in the shower head ?
BB
2003 Yukon R Pod 196 |
Page <1 23456 78> |
