  New Posts New Posts RSS Feed: Hot water conservation valve 2021 193
Hot water conservation valve 2021 193 - Event Date: 28 Mar 2022
MoMike View Drop Down
Post Options Post Options   Quote MoMike Quote  Post ReplyReply Direct Link To This Post Calendar Event: Hot water conservation valve 2021 193
    Posted: 28 Mar 2022 at 2:38pm
How do you set valve for return.
Seems no matter which way, I see no differance?
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 3:02pm
Please give a bit more information.  Are you attempting to go from winterization mode to summer mode?  Do you have a 2 valve or 3 valve system.  What is the problem you are encountering.  If the pump runs and you get no water out of either the H or C faucet it could be as simple as not having the 3 way valve shut allowing air to enter the pigtail - this is the line used if you winterize by using RV antifreeze.
RoverPod View Drop Down
Post Options Post Options   Quote RoverPod Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 6:23pm
Are you talking about the shower miser valve in your shower?
2017 F150 XLT SuperCab
2020 rPod 180
Post Options Post Options   Quote MoMike Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 6:26pm
Yes. I guess it's a shower mixer.
To return water, rather than waste.
Post Options Post Options   Quote MoMike Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 7:02pm
Your responses are making me think. First outing with this unit. I'm on city water. Therefore why would I need to conserve water? My understanding it is to return to fresh water tank until warm water temp is reached. Can try using it when dry camping.
Now curious on how it functions.
Post Options Post Options   Quote RoverPod Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 6:10pm
2020 rPod 180
