  New Posts New Posts RSS Feed: Awning question?
Awning question?
_WW_ View Drop Down
Post Options Post Options   Quote _WW_ Quote  Post ReplyReply Direct Link To This Post Topic: Awning question?
    Posted: 17 Mar 2022 at 11:22am
We have 2016 179 and the room that attaches to the side. What I'm wondering is if we can install an awning also. Is there framing support for one? I had heard that if it didn't come with one that you cannot attach one. Is this true?
2014 RAM 1500
2016 R Pod 179
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2022 at 12:07pm
You can easily attach an awning to the keder rail that runs along the top on the non-slide-out side. However, having a retractable awning similar to what comes on some new Rpods requires framing support to be built into the wall, which your Rpod will not have.
Pod People View Drop Down
Post Options Post Options   Quote Pod People Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2022 at 9:18am
We also have a 179 and constructed our own awning.  we bought keder tape from an online source and sewed it on the edge of an 8'x12' tarp. We use 3 adjustable poles and it works great.
Safe travels
Vann
Vann & Laura 2015 RPod 179
_WW_ View Drop Down
Post Options Post Options   Quote _WW_ Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2022 at 9:35am
I like the Keder tape and tarp idea. Does that tape slide in and out easily?
2014 RAM 1500
2016 R Pod 179
Post Options Post Options   Quote lostagain Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2022 at 11:07am
An alternative to using Keder tape is to use sail slides, spaced at a convenient distance.  Since they usually made of a hard plastic or nylon, they move easier through the rail and tend not to get stuck like the tape can.  They are available in various sizes to fit the different rail sizes.  Here is an example of what they look like: https://www.velasailingsupply.com/ronstan-sail-slide-stainless-bail-48mm-x-11mm/?sku=RONPNP103&gclid=Cj0KCQjw29CRBhCUARIsAOboZbIRomkJP2-Uirsl5To515l-lTw58NjavVz3LFCkkwi--qvYhDIfn_gaAnKmEALw_wcB
Post Options Post Options   Quote Pod People Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2022 at 8:24am
the keder tape will slide in the channel.  However, sometimes the screws  holding the channel in place have not be tightened properly and the heads will protrude, causing some resistance.  Once you tighten the screws, it will slide easier.
I have also used a dry spray lube that helps.  Overall, it is still a great system and we are happy with the results.
safe travels
Vann
_WW_ View Drop Down
Post Options Post Options   Quote _WW_ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2022 at 10:10am
Many thanks for the ideas guys!
...Wayne
2014 RAM 1500
2016 R Pod 179
EchoGale View Drop Down
Post Options Post Options   Quote EchoGale Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2022 at 3:59pm
I'm traveling so sewing the keder strip isn't possible. I'm using heavy duty suction cups, adjustable poles and a "sail shade" all from Amazon for about &75. It's working really well. Maybe this link will show it off:
https://twitter.com/julieingersoll/status/1500942653935931394?s=20&t=6fpeHaN1-4Ho8BIxpkGHUg
Julie
poston View Drop Down
Post Options Post Options   Quote poston Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2022 at 4:06pm
Just putting it here for easier viewing:
Jim
Virginia City, Nevada
2016 R-pod 180
2015 Nissan Xterra Pro-4X
Post Options Post Options   Quote EchoGale Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2022 at 4:09pm
That was very kind of you, thanks. I've had no luck with the posting process within the forum.
Julie
