  New Posts New Posts RSS Feed: battery reading too high
EchoGale View Drop Down
Post Options Post Options   Quote EchoGale Quote  Post ReplyReply Direct Link To This Post Topic: battery reading too high
    Posted: 24 Feb 2022 at 1:02pm
Hi folks,
I went to check my battery charge with my volt meter this morning and got a reading of 15.4.
I am not plugged in (so they aren't actually charging) and they read 12.5 yesterday.
I have two 12v set up in series. They've been fine so I know they are connected correctly. Water level is good.
I disconnected them from each other and tested them separately 15.4
Could the problem be my voltmeter? Any other thoughts?
I appreciate the help.
Julie
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2022 at 2:36pm
That was my first guess before you mentioned it.  I have seen 14.6 - 14.7 when plugged in with a 2 amp trickle charger.  Try your car battery and see if you also get a high read.  If so, purchase another voltmeter, they are pretty cheap.
Post Options Post Options   Quote EchoGale Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2022 at 2:46pm
Thank you. I put off checking the volt meter because my car battery is so hard to get to. (back of a fully packed suv).  I'll get to work  :)
Julie
Tars Tarkas View Drop Down
Post Options Post Options   Quote Tars Tarkas Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2022 at 6:42pm
You might try putting a new battery in the meter first.
Post Options Post Options   Quote EchoGale Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2022 at 7:43pm
I came back to post an update and found the most recent suggestion about changing the battery--which is what I had just done. After a few fits and starts I ended up opening the device and found the battery to be leaky.  Got a new one (also no small thing because there no real shopping here; it was a 9 volt and I had to go the 3 places).
All's well that ends well though. Thanks to you both for helping me think through it.
Julie
Julie
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2022 at 8:16pm
Glad it was an easy fix.  Good thing you are smart and know what to do and how to fix it.
Post Options Post Options   Quote Tars Tarkas Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2022 at 8:20pm
Excellent!  Thanks for reporting back!
