  New Posts New Posts RSS Feed: heater
heater
hogone View Drop Down
Post Options Post Options   Quote hogone Quote  Post ReplyReply Direct Link To This Post Topic: heater
    Posted: 18 Feb 2022 at 7:50am
Has anyone tried those 500 watt plug in heaters.......wide array of reviews.   Good? Junk?  Thoughts?  jpp
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 7:59am
I cannot directly address your question concerning a 500 watt heater but can concerning the 750 - 1500 watt plug ins.  We usually are not in a position to use electricity as we usually boondock but for those occasions where we have it, the 750 watt option works quite well as long at the temps are 40 and above.  When using the 1500 watt option, after 5 minutes or so the breaker will pop and you will have to re-set it.
If and when you get one of these make sure it has the safety button underneath so that in the case IF it gets tipped on its side it will automatically turn itself off.
Post Options Post Options   Quote hogone Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 8:15am
guess I should clarify, my bad.  meant the small little plug in heaters the size of a small smoke detector that plugs directly into the socket, no cord.  One brand is top heat, but theres many others out there.  If Im not descibing clearly, sorry.
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
meant outlet!!
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
