Ridgeline Towing - Event Date: 27 Jan 2022 - 27 Mar 2022 |
Page <123> |
![]() ![]() ![]() ![]() Posted: 29 Jan 2022 at 1:05pm |
Not sure why but all this just makes me want to go out an buy a Honda Ridgeline, an RPod 195 trailer, and a telescoping ladder. Maybe I'm suicidal. |
FJ Cruiser |
Could it be that you're just a bit cantankerous in your dotage?
Dirt Sifter ![]() Senior Member ![]() ![]() Joined: 30 Dec 2018 Location: Right side OR Online Status: Offline Posts: 170 |
Greg n Deb 2020 195 HRE
'07 Tundra 5.7L., '17 Tacoma 3.5L. Both with tow packages 1 Puggle, 1 Chihuahua support staff |
I am a lot closer to my dotage than I used to be but insults help. Actually, I have never cared for people making statements like only they know best, especially when there is obviously (plenty) of room for other valid opinions. Note that the OP asked for guidance from other Ridgeline owners. He's gotten none, including from me. The most opinionated advice he's gotten is from someone who bases his response on his experience as a solar engineer and as the owner of another vehicle. I stated earlier that at the bottom line I agree with Offgrid. By the numbers, the Ridgeline is not a great choice for towing a 195. In the long run that combo is likely to make the owner unhappy. Is it doable? Yes, with care and some caveats perhaps. Assuming the OP has a Ridgeline already and doesn't want to swap it out for a bigger truck or SUV, I think a smaller, lighter trailer would certainly be a better choice. The difference is between recommending against the Ridgeline and stating that it won't work. TT
FJ Cruiser |
Tars, lighten up, you're going to drive up your blood pressure. I was only trying to pull your leg in my post, which is why I put the "wink" emoji after it, so that no one would take it literally.
I think the OP was looking for someone who has actual experience towing a 195 with a Ridgeline and I suspect no one on this board has it. Assuming the good faith of our fellow board members wanting to be helpful, it looks to me like many, including you, were suggesting that we should not tow stuff beyond the capacity of the TV and trailer's capacity and safety margin, all in an effort to be helpful. Some may be more blunt while others more circumspect, but everyone did his/her best. So it's all good. Be happy.
TT, why would you say I base my response on being a solar engineer? I base my response on an engineering analysis of my Highlander/179 combo and my personal experience driving that rig. The Highlander and Ridgeline have very similar capabilities. The 179 is much lighter and smaller that the 195. I considered my rig to be acceptable but not optimum because I needed to carefully monitor weight, a heavier tow vehicle would have been better.
The analysis portion is a simple problem in statics that any 1st year engineering student should be able to solve. Heck, it's done for you in the towing calculator, all you need to do is plug in some numbers. The only thing I am using my professional background for here is to avoid being fuzzy in my response, because as I explained I have learned that doesn't do anyone any favors. Folks are either looking for clear input or have already decided to do whatever it is and looking for justification to make them feel better about it. Either way, it goes without saying it's a personal choice, folks can ovbiouy do what they want, there are no towing police out there going to stop you. Well I guess maybe there are in extreme circumstances, if you were towing a 35 ft triple axle trailer with a compact SUV the state police would probably pull you over. Whether you look at that as the officer doing his or her job or as unreasonable governmental interference is up to you. So feel free to ignore my posts, it's ok with me. If my response makes you or anyone want to buy a 195 and a Ridgeline just to show something can be done, that's also up to you. But it wouldn't be convincing, any more than not falling off a cheap ladder or any other anecdotal report is convincing. Safety is a game of statistics, by selecting the right ladder or the right tow vehicle we are trying to take the accident rate down from one in 1,000 to 1 in 100,000 or similar math. You would need thousands of cases to demonstrate that kind of difference. Lacking that, we must fall back on analysis and experience in similar circumstances, resulting in the establishment of appropriate safety factors, which is what I did. |
And on a lighter note, we all understand that knowing the equipment we're talking about is important; thank goodness the 195 comes with its own ladder attached.
And every time I start climbing up my 195 ladder, I think to my self, "This ladder is the same quality as everything else forest river put in / on this camper, I hope I make it"
Btw I completely agree with the "relativity" argument when it comes to tow vehicles. If you intend to pull a camper to a place, maybe an hour or two away from the house, a couple times a year, the "what works" numbers are much different than if you are towing very often, to destinations 8 or more hours away. It might not be a comfortable towing experience when your almost maxed out, but it will work if your careful. I don't buy snap on tools for every nut I need to tighten, sometimes I buy the cheap import that isnt rated to last a lifetime, and it works.
John D ![]() Newbie ![]() ![]() Joined: 25 Jan 2022 Location: Port St John, F Online Status: Offline Posts: 3 |
Thanks for your reply. We do not intend to tour the U.S. We plan to travel light and I have weighed the trailer and we come up to less than 4,100 lbs while we are rated for 5,000 lbs. We have installed a WD hitch, brake controller, cameras, etc.
Page <123> |
