FURNACE |
hogone ![]() Senior Member ![]() ![]() Joined: 09 Apr 2013 Location: St. Louis Online Status: Offline Posts: 1060 |
![]() ![]() ![]() ![]() Posted: 24 Dec 2021 at 8:49am |
Im pretty sure this has been discussed, but cant find! Turned furnace on last night and air comes on as well, and flashing E4. Thoughts? Merry Christmas. jpp
Jon & Pam
texastreehugger ![]() Newbie ![]() Joined: 09 Oct 2021 Online Status: Offline Posts: 17 |
I don't know about the e4 error but our 2016 Rpod has to have the thermostat set to auto, otherwise the AC fan goes on along with the furnace.
I searched dometic thermostat and found a couple of posts on the error http://www.rpod-owners.com/forum_posts.asp?TID=13562&KW=thermostat+dometic&PID=131350&title=ac-error-code#131350 and explanation of the thermostat settings http://www.rpod-owners.com/forum_posts.asp?TID=9457&KW=thermostat+dometic&PID=89193&title=my-ac-and-furnace-wont-work-but-fan-runs#89193 Hope this helps! Merry Christmas!
2016 Rpod 182g
2022 Chevrolet Colorado 4x4 |
RoverPod ![]() Senior Member ![]() ![]() Joined: 07 Mar 2020 Location: Virginia Online Status: Offline Posts: 118 |
On the rPod, the E4 error is a false error. That error signifies the outdoor sensor being disconnected. We don't have an outdoor sensor on the rPod. Disconnect from shore power and disconnect your battery for a few minutes. Then reconnect. This should clear the error. And as noted above, be sure that you have the thermostat fan set to AUTO so that the fan on the air conditioner doesn't come on with the furnace.
2017 F150 XLT SuperCab
2020 rPod 180 |
Ill give it a shot, many thanks. jpp
Jon & Pam
