Essential Tools for an RV Toolkit |
Page 12> |
Susan_55 ![]() Newbie ![]() Joined: 01 Dec 2021 Location: Sequim, WA Online Status: Offline Posts: 12 |
![]() ![]() ![]() ![]() Posted: 10 Dec 2021 at 1:04pm |
I'm putting together my tool kit for my new-to-me 2014 178 HRE. What are your essential/most used tools? Do you have favorite gadgets for specific uses?
2014 R-Pod 178 HRE
2015 Toyota Tacoma 4WD V6 on the beautiful Olympic Peninsula, Washington State |
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3365 |
#1 is multitester to check battery voltage #2 floor jack (2 ton) in case of flat, bottle jacks are too tall to fit when tire is flat #3 appropriate socket for lug nuts on your rpod and ratchet with extension or 4 way lug wrench #4 tool set from Harbor Freight which includes 3/8 and 1/4 inch sockets/ratchets as well as other specialty bits that come in a handy plastic case #5 L.E.D. flashlight(s) #6 plug in tire pump #7 tire pressure gauge #8 set of 3 emergency reflectorized triangles in case of breakdown. this is only a start of some basic essentials.
Thanks, Jato. This is a great start. I love Harbor Freight, and one of their tool sets was already on my list. What do you think of this? I like that it's a little smaller and lightweight, but the price makes me think it's cheaply built, even though it gets good reviews. https://www.harborfreight.com/2-ton-compact-trolley-jack-64874.html
2014 R-Pod 178 HRE
I am old school in that if it seems to good of a price to be true . . . .anyway your words are resonating . . .yes probably cheaply built but on the other hand hopefully you won't need to use it very often if at all. Also purchased a 2 ton trolly jack from HF 6 years ago and paid $ 89 for it. Pretty nice as it comes in its own plastic case and has been used a lot for changing (summer to snow) tires and rotating them as well. Works well lifting our Explorer and F-150.
I was able to avoid carrying a dedicated jack for the trailer once I found that my Highlanders scissors jack did a great job lifting it. It is one of those jacks with a slot to engage a flange on the rocker panel and it worked perfectly to engage the flanges on the rpod axle that attach the axle to the frame. The point is to take a look at your tow vehicle jack to see if it will also work on your trailer before going to the expense and added weight of a floor jack.
My tow vehicle is a 2015 Toyota Tacoma 4WD V6 with a factory tow package. I'll take a look at the jack. Good thought. Thanks!
2014 R-Pod 178 HRE
Colt ![]() Senior Member ![]() ![]() Joined: 16 Nov 2019 Online Status: Offline Posts: 383 |
Multimeter
electric screwdriver and adapter to raise/lower stabilizers 2 or 3 sizes of both screwdrivers Sockets for lug nuts or tire tool Pliers, wire cutters, wire strippers emergency crank for electric tongue jack Small wrench set for "just in case" Air compressor and tire plugging kit I've never needed anything else. But, keep good tires and check the pressure often. |
John
'16 R-Pod 180 |
1nana2many ![]() Groupie ![]() ![]() Joined: 05 Apr 2018 Location: NE Kansas Online Status: Offline Posts: 62 |
I will add:
a couple spare light bulbs for light fixtures if not LED a few of the blade fuses that match the ones in your control panel I would substitute a battery operated drill with charger for an electric one if you intend to boondock A roll of electrical tape and at least a few strips of waterproofing tape like Eternabond A tube of dielectric grease because sometimes the bulb didn’t burn out, the connection is just bad.
The mountains are calling and we must go...O.D., Keith & Jody
2016 RP179= O.D. (Olive Drab) 2008 Coachman Captiva 1993 Jayco 1206 popup 2016 F150 Supercrew |
We also carry some shark bites, a couple feet of pex tubing and a little bit of wire/connectors.
in case of any electrical or water problems. |
Okay, I had to look up shark bites.
2014 R-Pod 178 HRE
Page 12> |
