camping in the winter? - Event Date: 17 Aug 2018 |
Page 12> |
hermslx ![]() Newbie ![]() Joined: 15 Aug 2018 Location: Albuquerque Online Status: Offline Posts: 3 |
![]() ![]() ![]() ![]() Posted: 17 Aug 2018 at 3:12pm |
Hello all, looking for some info/advice about camping in sub-freezing temps for 5 days. I 'was' a class-c owner and it had the fresh h2o tank inside under one of the seats so never a concern. I am a newbie rpod owner and somewhat puzzled since the fresh h2o tank is outside of the unit. thx 2017 Rpod 178 |
Herm
How "sub-freezing" and for how long? Also, will you have an electrical hook up? I've "dry" camped into the low to mid 20s overnight however, it would get well above freezing during much of the day. I did nothing special. On the other hand, if the expected temperatures are going to be lower and sustained, I would be winterized (plumbing) and not use any water. The waste tanks will still be subject to freezing, even if nothing is in/used from the fresh water tank. If on battery(s), expect some extra effort. Battery capacity drops in cold weather and usage goes up (furnace). Expect more charging. Keep the bath fan vent lid open about 1/2" and/or a window to help prevent humidity build up. |
I lived in my Pod in the winter, most important part of David's post, electrical or boondock? I can give you tips if you are on electric. I made it for 90 days.
Dahuntsr ![]() Newbie ![]() ![]() Joined: 24 Aug 2021 Location: MI Online Status: Offline Posts: 10 |
Mike please share some of the things you learned. I love just sitting in a winter storm (10 inch+) and watching the snow fall. I retired this year and I'm watching for heavy snow storms that I can get in the path of and setup camp to watch it. I've invested in tank and pipe heating pads and a propane tank warming blanket. Also I've been using a space heater to reduce use of the furnace.
Did you dry camp or use your fresh water and holding tanks? I bought a 2017 R-Pod 177 in June. This is my second travel trailer but I didn't do any cold weather camping in that Innsbruck 25' I had when my kids were growing up. |
If you want to camp in blizzard conditions then the rpod is the wrong travel trailer for you. Get something designed for that purpose. The Oliver trailers for example. This is another case of getting what you pay for. Ropods are decidedly not 4 season TT's.
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Online Posts: 3324 |
+1 We have dry camped in our 177 when temps dip into the 30's and we are offgrid. When windy, the furnace runs more than it is off, battery will last only 2 days at that rate. And, as Offgrid points out, these are not a four season travel trailer. For me, when it gets below mid 40's all those walls around you feel like ice, I rather be inside my house with the wood stove crankin' and the temp is 80!
I've already done a "shakedown cruise" in my driveway with a wind chill in the low 20's. I had to turn the temperature up in the trailer to feel comfortable. As a result the furnace did run more. Since then I've added a space heater to do the bulk heating using the furnace for additional heat if needed. I haven't started using the propane tank warming blanket yet. Temperatures have only been dipping down in the 20's occasionally at night. That will change over the next couple of weeks. I think I will dry camp in cold weather. The heating pads will keep the tanks from freezing but won't keep the water lines from freezing.
If you're going to do serious winter camping in an rPod or similar 3 seasons trailer, you should add one of these: https://www.suremarineservice.com/Heat/Solid-Fuel-Heater/00-NEWSF.html?gclid=CjwKCAiA7dKMBhBCEiwAO_crFDvcJC-_6iHMYGexQ7buciLPwO6uDQrIXKAit_a5xH5tWHUNKydTdxoC9f8QAvD_BwE
It'll keep you nice and toasty without running down your battery of giving you CO poisoning, provided you install the chimney.
EchoGale ![]() Senior Member ![]() Joined: 10 Mar 2019 Location: FL Online Status: Offline Posts: 469 |
As I've been traveling across country I've camped many nights with temps just below freezing. Whether on electricity using a space heater, or on battery using my propane heater, I've been toasty warm. I've done this just one night at a time and never below freezing for more than a few hours. When I have electricity there's nothing like by electric blanket/throw.
Julie
The water lines can be protected from freezing by recirculating water from the fwt through them. The technique is similar to that used to maintain instant hot water in home plumbing lines far from water heater.
A solenoid valve is placed in an new line connecting the cold line back to the fwt. The hot line is connected to the cold line wtjough a second solenoid valve at the far end of the lines from the pump and water heater. A tstat is used to monitor line temp at the fwt connecting to the line feeding the pump (which should be the coldest spot). When that point approaches freezing the pump will turn on which will circulate water throughout the system as well as in the tank itself. Add inside cutoffs for the outside shower and you should be good to go. And no electric heating pads which you can't use without shore power hookup. That doesn't help with the black and gray water systems (if you want to be able to use those) nor does in improve the very poor insulation of the trailer itself. |
Page 12> |
