  New Posts New Posts RSS Feed: counter top laminate peeling
Post Options Post Options   Quote David and Danette Quote  Post ReplyReply Direct Link To This Post Topic: counter top laminate peeling
    Posted: 15 Nov 2021 at 2:47pm
 I replaced the counter top in our r-pod 171 and our forest river Vibe with plywood the mdf that forest river uses doesn't work well if it gets wet. When I replaced the sink in our Gulfstream Vista cruiser I was happy to discover Gulfstream used plywood something more RV manufacturers should do.
2014 Ram 1500 Quad cab
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2021 at 5:24am
Edmonton might be a little nippy for you this time of year...
I agree with GlueGuy, if the partical board has gotten wet it will need to be replaced, there is no getting things to stick to that stuff if it's been damaged and is swollen. If a trip to Edmonton is not an option then maybe try a local shop that does laminate kitchen countertops. It shouldn't seem like a big job at all to those guys. An RV shop will charge you an arm and half a leg. But sure to have them use plywood and not more crappy particle board. It will inevitably get wet and swell again.
Post Options Post Options   Quote David and Danette Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 3:51pm
 EchoGale you could park in marwayne's driveway with your camper that would be like living next door.
Post Options Post Options   Quote marwayne Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2021 at 7:42pm
Well, if you lived next door to me, I might consider it.
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2021 at 5:16pm
Originally posted by StephenH
For laminate, contact cement is the proper glue to use. For repair of damaged spots though, that is much more difficult. When I worked at place that did a lot of laminates, contact cement was what was used. Brush it on, let it dry, then bond using the suggestions by Colt to use spacers to keep the parts apart until the contact cement dries to the right stage for bonding. The can will tell you how to use it. With contact cement, clamping is generally not needed once it is bonded. Just pressure with a good roller to make sure the laminate has made the best contact possible and all air bubbles are moved out.
If it's just the laminate that's lifted off the substrate I agree. However, if the particle board underneath is frangible, then the primary thing is to get the particle board back together. I guess it's a judgement call.
EchoGale View Drop Down
Post Options Post Options   Quote EchoGale Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2021 at 2:59pm
I love it. But I don't have those skills. You volunteering?  :)
Julie
Post Options Post Options   Quote marwayne Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2021 at 2:30pm
If it was mine i replace the counter top with 3/4" plywood and flat work laminate with solid oak edging.
Post Options Post Options   Quote EchoGale Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2021 at 10:19am
Thanks for the help
--Julie
Julie
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2021 at 2:56pm
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2021 at 12:58pm
Don't use Elmer's. Use something like Titebond III or Titebond Ultimate. This glue is stronger than wood, and the ultimate version is even water proof.
