Winterization My RPOD 177 |
Wengerda ![]() Newbie ![]() Joined: 02 Jul 2021 Location: Alexandria VA Online Status: Offline Posts: 8 |
![]() ![]() ![]() ![]() Posted: 23 Oct 2021 at 10:54am |
Question, newbie here. I winterize my R-POD using the hose under the sink and the water pump. I by passed the water heater too. After I was done, I forgot to ensure that my black and gray tank was completely empty. I empty both tanks after I winterize the camper. Now do I need re-winterize the POD after opening both tanks. I did add more pink stuff in the traps after I empty the tanks. TIA
Black and gray tanks can have several gallons in them. Dont sweat it
Thanks.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2707 |
+1
Main thing is to empty the water lines & have a little pink stuff in the traps. Also the WH should be drained. All of the under-carriage tanks can just be drained; they don't need to be 100% empty.
Great.
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3340 |
Did you use compressed air or use the pigtail under the sink to suck up the antifreeze to send throughout both water lines?
I used the pigtail under the sink.
make sure the low point drains are emptied Vann
