AC bat out of hell fan |
![]() ![]() ![]() ![]() Posted: 04 Oct 2021 at 4:24pm |
I just installed an EasyTouch thermostat but haven't really given it a comprehensive test due to lack of sufficient power for AC in my storage unit. I did test it on fan and furnace, but I didn't actually check to see if the fan setting affected the AC unit when the furnace was on.
Alan
DaveB1701 ![]() Newbie ![]() Joined: 24 Jun 2021 Location: Green Bay, WI Online Status: Offline Posts: 36 |
My '21 171 has the Dometic 'touch capacitive' thermostat, that unfortunately, after 4 trips out, is becoming a push button thermostat, and likely on the road to failure as many others have reported. Personally, however, I like the fact that the thing can be set on low fan, then for furnace operation. The '21 171s furnace outlet is under the roadside dinette seat, and the A/C fan moves the warm air back to the sleeping area. Of course, if you prefer to sleep in dead silence, this is not an option. But I now leave my 'white noise' generator at home - one less thing to pack, and the birds don't wake me up @ 4 A.M...
2021 R-Pod 171
2017 Chevy Colorado Z71 V6 Just me & my pooch Mr. Buster... |
My 2015 179 had separate tstats for the a/c and furnace. Worked just fine no problems, confusion, or weird interactions. Since the furnace does not need 120Vac for anything I think it's a much better design to keep that completely separate from the a/c. No reason to have them interconnected. The furnace is just looking for a contact closure calling for heat to turn on, and an open on those lines to turn off.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6422 |
It has been that way for several years. Our 20016 RP179 is that way. To keep the AC fan from running when using the furnace, set the fan to Auto. If running the AC though, having it on Lo so it runs constantly is better than hearing it cycle on and off and change speeds during the night.
Means it blasts air like crazy and is really really really loud. ![]() I still don't get why FR thought it was an "improvement" to tie the heater tstat in with the a/c. Didn't used to be like that and everything worked fine, now there seem to be no end of complaints and issues with the newer integrated system. Cheaper maybe? |
On the thermostat, set the fan to "auto" not hi or low. That will stop the fan from turning on when heating.
RoverPod ![]() Senior Member ![]() ![]() Joined: 07 Mar 2020 Location: Virginia Online Status: Offline Posts: 118 |
No idea what you mean by 'bat out of hell fan". But you need to set the fan in the thermostat setting to OFF in order to not have the air conditioner fan come on when the furnace is on.
2017 F150 XLT SuperCab
2020 rPod 180 |
Leomillan ![]() Newbie ![]() Joined: 25 Sep 2020 Online Status: Offline Posts: 7 |
Ok, running the furnace heater when off grid all works fine. However when I am hooked up to shore power and I try to run the heater the overhead "bat out of hell fan" from the AC unit kicks on blowing cold air and is extremely noisy. I have not found how to run just furnace fan when hooked to shore power, there seems to be no options I can find on the thermostat... Anyway to make this work right?
Thanx in advance... Cheerz
