12 volt only solar setup? |
Post Reply | Page <123> |
Author | ||
Topic: 12 volt only solar setup? Posted: 28 Aug 2021 at 12:01pm |
If you're referring to the ac to DC converter I believe WFCO makes an ac to DC charger aka converter that is plug and play compatible with the existing one and is set up to replace it for charging Li batteries. I would go that route (or check with Progressive Dynamics if you don't like WFCO) rather than add another component in series with the existing converter which has a complex multistage charging profile, not what you want for Li batteries. If youre talking about a DC to DC converter so you can charge the Li batteries from the TV that would be a new installation not a repolacement in a location of your choice so you can do what you want. Several manufacturers make them. |
Mr. Scott
Groupie Joined: 08 Jun 2017 Online Status: Offline Posts: 46 |
Posted: 28 Aug 2021 at 3:00pm | |
Yeah, referring to the existing AC to DC converter to make it Lion friendly. Thanks! I'll check that out. But, yeah, I'll need the DC to DC converter, too, because I want to charge from the TV. Jeez, I need a schematic! At least a basic one. LOL. I think for obvious reasons I want to be able to charge from a land line, the TV, and the solar. So it looks like three different parts: 1) AC to DC converter (basic swap) 2) DC to DC converter (for TV)--this one is more mysterious for me re. placement. 3) Solar charge controller--simple in line with the solar panels to the batts So that covers it, yes? Besides, of course, busses, fuses, etc. My head hurts. Thanks.
Posted: 28 Aug 2021 at 3:11pm | |
Posted: 28 Aug 2021 at 3:48pm | |
DC to DC: You can see where I put mine in my mods listing. I placed it near the battery. The drawings on Renogy's site are more geared toward a motor home where it will be close to the engine compartment and can be connected to a circuit that is only live when the ignition is on. That triggers the charger to turn on. When power is removed, that triggers it to turn off. On my installation, since i have the separate power circuit, I just draw power from that to the switch since it is only live when the engine is running and the isolation solenoid is closed. When the engine is off, the isolation solenoid opens and the circuit has no current. Thus, the DC to DC charger shuts off. Solar: Yes, it is easy. Since you won't have the converter or the DC to DC charger trying to charge the battery, your solar panel's charge controller will handle the charging just fine. Connect it directly to the battery or run a connection to where you can use an Anderson PowerPole connector. Make sure to get the rubber waterproof boots to install as well so your connections stay dry both when connected or disconnected. These beat the solar MC4 connectors because it does not require a tool to disconnect them and they are much heavier duty so with something that will be plugged and unplugged many times, the Anderson PowerPole connectors are much better. If, like me, you mount the LiFePO4 battery and DC to DC charger inside the RPod, you will want connectors that are easy access from the outside anyway. The PowerPole connectors with the boots work well.
Mr. Scott
Posted: 28 Aug 2021 at 4:13pm | |
Awesome. Thank you. It will be a couple of months at least before I start buying parts, but this discussion is really going to help.
Posted: 28 Aug 2021 at 7:24pm | |
Be sure to build in proper fuse and/or circuit breaker protection. Each current producing device needs to be fused at the source to protect the wires coming from it. 10 gauge 30A, 8 gauge 40A, 6 gauge 50A. The exception is the solar circuit which needs a fuse or cb at the battery but not the solar end because solar is self limiting in current. All fuses breakers, and switches go in the pos conductors.
Posted: 28 Aug 2021 at 7:30pm | |
StephenH, you could do the same thing using the +12V from the Bargeman to turn the DC DC on and off. Either way, it's a good point that anyone doing this would need to either disconnect their trailer connector as soon as they stop or run a wire from their ignition to the DC DC on/off input, otherwise they will draw down their TV battery trying to charge the trailer battery.
Posted: 28 Aug 2021 at 8:03pm | |
Posted: 28 Aug 2021 at 8:24pm | |
You don't need to have a second connector to do that. If you run your solenoid output to the TV +12V pin on the Bargeman it would do the same thing.
Posted: 28 Aug 2021 at 10:07pm | |
