Page 12> |
Noahp ![]() Newbie ![]() Joined: 18 Aug 2021 Location: MI Online Status: Offline Posts: 4 |
![]() Posted: 24 Aug 2021 at 11:57am |
I went to un-hitch the other day and my electric jack wouldn’t work. I realized that the in-line fuse was blown, so I replaced and as soon as I press up or down, the fuse blows. I don’t see any shorts or grounding issues.. any suggestions?
Thanks, Noah |
AugiePal ![]() Newbie ![]() Joined: 22 Aug 2021 Location: Chicago Online Status: Offline Posts: 5 |
If the fuse blows when you hit the switch there is a short. Just off the top of my head I would probably replace the electric tongue jack.
Do you have a multimeter? If so you could use it to try to find the short. It could also be the jack is locked up and the motor is drawing too much current trying to turn it. You could try freeing up the jack using some penetrating oil and see if that works. Otherwise you will probably need a new jack.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6422 |
You should have a handle to use in this case. If so, you can check to see if it is locked up. That also might get it back to working once you turn it a few times.
Thank you all for the replies.. I’ll do some investigation.
RFrog ![]() Newbie ![]() ![]() Joined: 10 May 2021 Location: Santee Online Status: Offline Posts: 16 |
Mine didn’t come with a crank (bought the unit previously-loved), and the first semi failure/stubborn hissy fit of the jack I ordered that key pronto. I ended up needing it, and ultimately ended up needing to replace the whole landing gear/jack. Of course the new one came with a crank and it’s different than the old one.
~dani~ 2019 RP180 purchased 5/15/21; towed by 2014 Willys Jeep Wrangler Unlimited
ERS1977 ![]() Newbie ![]() Joined: 30 Jun 2021 Location: ON Online Status: Offline Posts: 7 |
Have you tried using an electric drill or manual socket wrench to raise/lower the jack? This would ensure the jack is not seized.
Colt ![]() Senior Member ![]() ![]() Joined: 16 Nov 2019 Online Status: Offline Posts: 383 |
Using the manual crank is surprisingly easy. I would not hesitate to change it for a manual, either.
John
'16 R-Pod 180 |
I thought the stabs handle would also fit the jack? Maybe not. |
Not on my 180, unfortunately. I checked that prior to ordering. It was not an expensive item, so well worth it. I agree it is surprisingly easy to hand crank. Did not try using my impact driver in lieu of the crank because once it seized I was out. Just give me stuff that works, please.
Page 12> |
