  New Posts New Posts RSS Feed: Black tank won't drain
Topic ClosedBlack tank won't drain
Direct Link To This Post Topic: Black tank won't drain
    Posted: 23 Aug 2021 at 8:51am
You might also go to the TankTechs web site to view the videos they have there. I think you will find them helpful and informative.
1nana2many View Drop Down
Direct Link To This Post Posted: 23 Aug 2021 at 8:28am
Camco makes a great black tank clean out called the Camco RV Flexible Swivel Stik that I highly recommend. It really does a great job cleaning out those stubborn areas after we have had our grandkids in our larger camper for a week. We threw out the plain pipe that just had a few holes drilled in it after getting this. It really was a game changer. We wipe ours down with Clorox wipes after use and keep it in a canvas bag I made for the purpose.
The mountains are calling and we must go...O.D., Keith & Jody
2016 RP179= O.D. (Olive Drab)
2008 Coachman Captiva
1993 Jayco 1206 popup
2016 F150 Supercrew
SC for Huskers View Drop Down
Direct Link To This Post Posted: 22 Aug 2021 at 3:15pm
Hey Gang,  Why can't Sharon68 use the Reverse Flush Valve?  You can probably barrow one from another campsite, or purchase one at the local camper equipment store.  Don't you think it would sort of juice up the stuff from the bottom up?
Happy Traveling,
Tom
2017 172pod
2011 F150 STX
DavMar View Drop Down
Direct Link To This Post Posted: 22 Aug 2021 at 2:41pm
Listen to Jato advice.
One thing every camper owner should consider owning and having with them at all times is what is called a "sewer or toilet wand". This is simply a 4 foot section of 1/2 PVC that you connect to an on/off water valve that you connect to a water spigot hose. I carry mine inside my extra sewer pipe carrier inside the pipe. If you run into the problem of a clogged black water drain you can open the toilet drain flap and insert it into the tank and blast the clog free. Plus its great for flushing out the tank after a long trip or the end of the season winterizing clean up. I've never had to use it to blast a clogged up drain free but I did let my buddy borrow it for the same problem in his motor home rv.
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
Colt View Drop Down
Direct Link To This Post Posted: 20 Aug 2021 at 7:49pm
Wear a rain suit! 😎
John
'16 R-Pod 180
Direct Link To This Post Posted: 20 Aug 2021 at 7:29pm
+1. If nothing is coming out the big hole the the idiot lights aren't working.
You can rinse through with the garden hose to confirm but don't drink out of that hose afterwards
Direct Link To This Post Posted: 20 Aug 2021 at 4:30pm
How do you know the tank is 3/4 full?  If you are depending on the idiot lights on the panel . . . don't as they are notoriously inaccurate.  When my black tank is empty it sometimes reads 1/3 full and at other times 2/3 full - not dependable.
If you can look down the toilet and see liquid than chances are pretty good that you have a plug at the tank exit - open the drain and insert a stout stick or similar to break the plug loose.  If you cannot see anything down the toilet, for peace of mind, open your drain and then take a garden hose and insert it inside the toilet past the lid cover, turn water on and flush tank out that way.  If you are confident that the black tank flush works use that but make sure your drain is OPEN while doing this procedure.
Sharon68 View Drop Down
Direct Link To This Post Posted: 20 Aug 2021 at 3:51pm
Ieft the black tank sewer connection open the hose got full so I emptied that now the tank still is 3/4 full and won't drain out
Ssmith
