HillbillyMedic ![]() Newbie ![]() ![]() Joined: 15 Jan 2021 Location: WV-FL Online Status: Offline Posts: 11 |
![]() Posted: 23 Jul 2021 at 11:52am |
Are there any ideas out there for storing the drain hose? It doesn't seem to want to stay compressed, is bound to be somewhat dirty, etc.
Be careful.
SC for Huskers ![]() Senior Member ![]() Joined: 22 Feb 2017 Location: Goose Creek, SC Online Status: Offline Posts: 144 |
Hey there, my pod came with black storage pipe, outside, up under the floor and frame. A lot like this one. I added another one with square white pvc. It is shown on another other Youtube page. https://www.youtube.com/watch?v=p2etlCuL5Wo
Happy Traveling,
Tom 2017 172pod 2011 F150 STX |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6456 |
Look at my mods and you will see what I did. I used the 5" square PVC fence post and strapped it up behind the steps with strap aluminum. You will see two. One holds the drain hose and the other holds a 6' folding step ladder. I use a piece of PVC drain gutter with a couple of bolts run through a piece of small PVC pipe on each end to both stiffen the pipe and to give me something to grab to slide it in and out.
I did the same thing as Stephen. I found the 5" PVC fence post and cap at a local big box home store. I used right angle metal framing clips to attach it to the frame. the passenger side cap is riveted shut and the driver side is bungeed. the clear box next to the carrier is for the 45 degree clean out fitting. Vann
