Username ![]() Newbie ![]() ![]() Joined: 16 Jun 2016 Location: WASHINGTON Online Status: Offline Posts: 16 |
![]() Posted: 01 Jul 2021 at 1:26pm |
I have a confusing situation - at least for me. When our 183G is plugged in at our house all appliances work fine as well as all of the 110v outlets. As soon as I unplug from shore power the lights all still work, but none of the outlets have power. I read through the manuals and can't find anything on how to troubleshoot this. The brown inverter (or converter not sure) will hum when plugged in so the batteries are charging fine. I am not sure what could cause them not to work on the 12v system. FYI i have 2 6 volt batteries and not a single 12v. Any ideas on where to start?
Thanks. |
What you have is a converter, which converts 110VAC to 12VDC. What you don't have is an inverter, which converts 12VDC to 110VAC, and that's why the AC outlets don't work when not on shore power. None of the R-Pods come with an inverter except the newer ones, and then only if you order the solar kit.
Alan
Ok, I think that makes sense. So, if I'm wanting to be able to power an outlet when boondocking, I need to either be running a generator, or have a solar array with an inverter, or just add an inverter on it's own?
Yes. If you don't want to drag a generator along, a solar array would be preferrable in order to replenish the battery charge, but you could run an inverter without solar for a limited time. If you decide to go without solar, I'd highly recommend going to two 6V GC2 batteries to get the extra capacity and deeper discharge.
Alan
Thank you.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6456 |
Or, for roughly the equivalent capacity at a fourth of the weight, go with a 100A LiFePO4 battery. It will require other changes, but the battery will last much longer and not require the maintenance of a flooded Pb-Acid battery. See my mods for my LiFePO4 conversion.
There are plusses and minuses to each chemistry. Flooded lead-acid are heavier and can't be discharged quite as far as LiFePO4. On the other hand, lithium batteries typically don't do as well in the cold, which is something to consider if you want to do any wintertime camping. Also, LiFePO4 batteries are very difficult to get a handle on remaining charge because the voltage discharge curve is very flat.
Alan
It would help us to guide you if we knew what you wanted to run on 120vac from an outlet while boondocking and for how long.
If you want to be able to also run your microwave and/or air conditioner then you will need a generator. |
