  New Posts New Posts RSS Feed: EscaPOD Adventures - 2021 edition
Topic ClosedEscaPOD Adventures - 2021 edition
Direct Link To This Post Topic: EscaPOD Adventures - 2021 edition
    Posted: 23 Jun 2021 at 11:54am
I'm curious how much energy your new fridge will use. A duty cycle on the Secop compressor in hot conditions so we can calculate amp hours would be very interesting, if you don't have an amp hour meter installed already.
Direct Link To This Post Posted: 23 Jun 2021 at 12:06pm
For the LiFePO4 battery, I did install a meter that tracks amps in and out. Initial testing is very positive and parallels my experience with the FPSC cooler. Heavier draw while actively cooling, minimal draw when idling. In some ways, it seems to draw less than the FPSC cooler because in that, the fan was running constantly. This one seems to be more like a house refrigerator in that the compressor shuts off when it is not needed.
Direct Link To This Post Posted: 23 Jun 2021 at 6:02pm
Just as a swag based on experience with Danfoss vaccine fridges in the past I'll guess about 75-100 amp hours per day for maintenance in hot weather. Bet you'll want to add a second Li battery pretty soon....
Olddawgsrule View Drop Down
Direct Link To This Post Posted: 25 Jun 2021 at 7:47am
We stayed out at Horse Thief BLM right between Aches and Canyonlands NP's. Did you run along Potash Road? One of those 'don't miss roads'!
Now in the Overlander, We will return and run down in the Canyon into Canyonlands NP. That area could take a year to explore! What an amazing place!
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
Direct Link To This Post Posted: 25 Jun 2021 at 7:52am
II tend to camp out if the heat, so my highest readings are 22amps for the day (24hrs). Mine's a 58qt. I'm still running my 60ah Li..
Byways no Highways
2017 Tacoma
Truck Camper Build
Direct Link To This Post Posted: 25 Jun 2021 at 2:05pm
Just for clarity, the applicable units we need to look at are amphours per day. I'm sure tgats what you meant Olddawgsrule.
Amps are instantaneous current which should be around 6 amps for the Danfoss compressor when it's running. So say you're using 24 amphours per day that would be an average of 1 amp. With a 6 amp operating current that would be a duty cycle on the compressor of about 1/6 = 17%. So if you want to get the amphours per day but don't have an amphour meter installed you could just use a timer to get your duty cycle. The duty cycle is the on time divided by the total cycle time (time between one turn on and the next). You would need to time 2-3 cycles to be sure things were stabilized.
Direct Link To This Post Posted: 25 Jun 2021 at 2:21pm
Yup, tgats what I meant. Spell-checker is a %(^ch some times.
 I meter my usage and the Frig is the main usage. It surprised me as too how little they actually do use. Now be it know, this is a dedicated 12v Frig I use.
Byways no Highways
2017 Tacoma
Truck Camper Build
Direct Link To This Post Posted: 25 Jun 2021 at 2:22pm
 I meter my usage and the Frig is the main usage. It surprised me as too how little they actually do use. Now be it know, this is a dedicated 12v Frig I use. Not a 2 or 3 way unit.
Byways no Highways
2017 Tacoma
Truck Camper Build
