Page <123> |
Author | ||
![]() Posted: 14 Jun 2021 at 9:59pm |
Sounds like that's what is happening, but you might want to do the 'skid-pad' test I described just to make sure.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6422 |
seafans ![]() Senior Member ![]() Joined: 24 Nov 2017 Online Status: Offline Posts: 163 |
An easy way to check if the magnets are in working order it to check the continuity with an ohm meter. Both of the magnets should have about he same resistance.
pedwards2932 ![]() Senior Member ![]() Joined: 21 Sep 2020 Online Status: Offline Posts: 333 |
I need to read up on how the brakes work and dissassembly. Can you check continuity without disassembly? If the issue is a bad connection to the actuator it would seem just fixing the connection would resolve the problem without dissassembly.
Yes you don't need to disassemble.
If you get a multimeter with a Hall effect DC current clamp on you can measure the current to each brake. But don't place the clamp on near the magnets or the reading will be inaccurate. If you don't have a clamp on then disconnect the crummy insulation displacement connectors to each magnet and measure the voltage there. Then replace with proper butt splices. You can put your meter on the ohms scale and measure the resistance of each magnet while you have them disconnected. The Lippert brake manual gives you the resistance range. I found that even though I had voltage to both magnets and both were in the resistance range I was getting lower current through the pass side magnet, enough lower that it never grabbed hard enough to burnish properly. I rewired my brakes in series so they had equal current and turned the gain on the controller all on the way up. Then an agressive burnishing. Problem solved. |
Yeah that's right, I was confusing the two brands. I still wouldn't use either one without both my trailer brakes working properly though. |
Please check the cooler drum for grease contamination. This will solve your problem with the brakes. Check the lippert trouble shooting page and if one brake is that much difference in temp the magnets and/or shoes are contaminated with grease. This was the issue on both of my new R-pods.
I will check it if I have to dissassemble.....it is a 2018 that was bought used so not sure is that is the cause but is worth checking.
Mine were imbalanced like that with new brake assemblies that I installed myself. No grease, just variations between magnets and the fact that the right side brake gets less current than the left one due to the longer wire run. And several folks have reported bad connectors resulting in one brake not operating. It's well worth doing the electrical checks first.
Well that was an easy fix one of the wires on the right side brakes had come loose. I used a butt connector and heat shrink to reconnect. All should be good but I will test it.
Page <123> |
