  New Posts New Posts RSS Feed: DC outlets
DC outlets
Rodg Pod View Drop Down
Post Options Post Options   Quote Rodg Pod Quote  Post ReplyReply Direct Link To This Post Topic: DC outlets
    Posted: 14 Jun 2021 at 1:52am
I have a 2017 179. It does not have any DC outlets. Can anyone recommend a good spot for placement. Where did you tap into the wires, and how did you access those wires. The easiest spot I am considering is behind the TV which can be accessed by taking out the stereo. Thank you for your suggestions.
ronahue View Drop Down
Post Options Post Options   Quote ronahue Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2021 at 3:44am
Remove the inside wall of the upper cabinet by the entrance door you can place a DC/USB outlet there and tap into the power at the one of other switches. That's what I did.
Ron & Sharon
2015 R-Pod 179
2022 Nissan Frontier
Post Options Post Options   Quote lostagain Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2021 at 8:17am
I've put in two; one in our 172 and one in our Sonoma.  Each time I was able to route  a short run of wire from the distribution panel's 12v side to the destination with the wires concealed behind the wall.  I used 14 gau. stranded wire.  I connected the wire to a little used circuit with a 15 amp fuse.  Here's what I installed:  https://www.amazon.com/gp/product/B07P5MZ111/ref=ppx_yo_dt_b_asin_title_o04_s02?ie=UTF8&psc=1
Pod People View Drop Down
Post Options Post Options   Quote Pod People Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2021 at 8:24am
We also have a 179.  I  have added several Dc outlets
I added one on the front of the bed at floor level. I snaked a wire from the power center under the bath floor and  made a junction box under the bed. from there, I can access the area over the wardrobe or  add more wiring to go anywhere under the bed area.
I added one above the tv
I connected the wiring into the power panel and have fused the connection.
Vann
Vann & Laura 2015 RPod 179
TheBum View Drop Down
Post Options Post Options   Quote TheBum Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2021 at 11:20am
I mounted DC outlets (accessory and USB) and AC outlets for my inverter on the wall where the TV mount attaches. I ran a dedicated circuit under the shower, behind the drawers below the wardrobe and up into the space behind the stereo. My inverter is mounted in that space too.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2021 at 11:55am
Check my mods and you will see where I installed DC outlets.
Ben Herman View Drop Down
Post Options Post Options   Quote Ben Herman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2021 at 5:22pm
I added a double outlet behind the tv and added a small shelf to hold our iphones for charging. I just spliced into the power feed for the stereo (which we rarely use in any event).
Post Options Post Options   Quote Rodg Pod Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2021 at 7:33pm
Thank you everyone for responding. It is appreciated. I definitely have some outlets to install.
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2021 at 8:54am
If you pull out the audio box you can tap the 12v supply to it and feed it out through the adjacent wall. Easy to do and already fused at the panel.
Post Options Post Options   Quote TheBum Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2021 at 10:59am
Be careful not to overload the circuit. I ran a dedicated circuit so I could make sure I had the wire gauge and fusing necessary to handle the load.
Alan
Three cats
