  New Posts New Posts RSS Feed: New 195
Topic ClosedNew 195 - Event Date: 02 Oct 2020
RPodFan775 View Drop Down
Direct Link To This Post Calendar Event: New 195
    Posted: 12 Jun 2021 at 2:39pm
Wonderful - thank you!
mjlrpod View Drop Down
Direct Link To This Post Posted: 12 Jun 2021 at 10:39am
I used these in the pantry, and in the wardrobes next to the bed. They have clips that can be adjusted about every half inch or so. I have had these in my pantry for two years and I put a lot of weight on my shelves. Can goods, water, etc.. never had a problem.  You can get them at lowes/home depot too.
https://www.amazon.com/Knape-Vogt-Shelf-Standard-length/dp/B001DT3158/ref=sr_1_94?crid=2YNLSKTV6QV0G&dchild=1&keywords=adjustable+shelf+brackets&qid=1623512011&sprefix=adjustable+shelf+br%2Caps%2C190&sr=8-94
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 11 Jun 2021 at 8:17pm
Hi 1955Shoebox,
I want to replace those pantry shelf brackets too. Do you remember where you got them? They have to be kinda slim, and I didn’t find any that thin at Home Depot today. Thanks.
Ricktoon View Drop Down
Direct Link To This Post Posted: 02 Jan 2021 at 12:45pm
Sounds like great mods. Do you have any pictures of extending the bed to fit the queen mattress and the doors under the bed?
Rick and Ellen B
2019 Chevy Colorado
2021 Rpod 196
Dirt Sifter View Drop Down
Direct Link To This Post Posted: 08 Nov 2020 at 6:32pm
Nice mods. Double check to make sure the medicine cabinet is properly mounted to the studs and not just hanging on the 1/8" wall board. One fix you might consider, if changing the shelf brackets in the pantry hasn't already addressed it; I added quarter round in the corners inside the door frame on each side from just above the bottom shelf to just above the top one. The shelves kept sliding forward against the pantry door and blocking it till then. Also put a couple command hooks on the wall left of the sink to hang the sink cover on to get it out of the way and added a paper towel holder above the sink per DW's direction. Taking the ottomans out opens things up nicely. Can see why you put doors under the full queen bed; I just stored enough stuff there that it added too much to the tongue weight.  Have fun!
Greg n Deb 2020 195 HRE
Direct Link To This Post Posted: 08 Nov 2020 at 9:10am
Be careful about adding dual cylinders and batteries, your tongue weight will go way up. Dual batts will add about 100 lbs and an additional cylinder about 40 lbs. If you need those mods you are probably a boon docker so might be carrying water too. Depending on what model you have that can add another 150-200 lbs to the tongue. You can easily end up well over 500 lbs, so be sure your tow vehicle is good for that.
For dual batteries most folks go with two 6V golf cart batteries in series. Battery size is GC2. You will need new battery cases as well, and a single battery jumper. These will fit in the existing battery rack without modification.
There are several mounting kits for dual cylinders available. You will need to remove the existing single tank and mount the new kit. You can get an automatic switchover too.
tewjax View Drop Down
Direct Link To This Post Posted: 08 Nov 2020 at 8:10am
Congratulations and welcome! Did you do the mods or have them done? I'm especially interested in the dual tanks and batteries. And thanks for the font mod as I can read it!  lol
Colonel Podder View Drop Down
Direct Link To This Post Posted: 07 Oct 2020 at 8:37pm
Congratulations on the 195!
I have a 196 on order and would be interested in seeing pictures of the pantry and wardrobe mods.
Thanks.
Pod_Geek View Drop Down
Direct Link To This Post Posted: 03 Oct 2020 at 10:56am
Originally posted by podwerkz
Hello, font police? calling the font police....font police, are you there? Hello?
Hey, at least it wasn't ALL CAPS...
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L
podwerkz View Drop Down
Direct Link To This Post Posted: 02 Oct 2020 at 10:35pm
