2hotchilis
Topic: Swapping toilet for composting toilet Posted: 29 May 2021 at 10:05am |
Hello, We are trying to outfit our pod, Lola to handle boondocking and traveling around the US. We have taken out our toilet but wanted to find out the best way to cap the water supply? We will keep the toilet in case we sell Lola later but now we are making a composting toilet. Has anybody capped their water supply and how did you do it? Also, I have heard of people, once they have swapped their toilet for a composting or cassette toilet some how merge their gray and black tanks to give them double the gray water storage. What's the best way? Thanks for any help with these issues. Darla
Posted: 29 May 2021 at 12:10pm |
You don't really want to double your gray water storage because the water weight that will add to the trailer. 60 gallons of water weighs 500 lbs and you'll overload the trailer frame and axle. Just leave the black tank empty.
The water lines are 1/2 inchbPEX so you need to get a 1/2 inch PEX end stop fitting. If you don't plan on any other PEX plumbing work you can get a push on fitting.
SC for Huskers
Posted: 29 May 2021 at 7:08pm |
I used something like this SharkBite from Lowes. You then have the 3/8 end in case you re-install. Item #849105Model #24947ZC
Happy Traveling,
Tom
2017 172pod
2011 F150 STX
podwerkz
Posted: 29 May 2021 at 11:29pm |
If your r-pod has combined black and gray dump, as mine does, you could temporarily cross-pollute the black and gray tanks by opening both dump valves but leaving the cap on. (you will need to spend an hour scouring the black tank with the black tank flush port before you do this)
But the cross filled gray water will probably leak from the twist cap seal... if so, you can add a third dumpvalve where the cap is now, and then modify the fitting, moving the cap past that point.
If your r-pod has separate dump fittings for black and gray then you will need to add some extra fittings and valves to make a single section of tubing combine the two with a T or a Y junction.
As OG points out, your rig will be way too heavy but maybe you only need to drive a few miles to a nearby dump station. I would NOT hit the highway with two FULL tanks...its just gonna be too heavy for the lightweight running gear equipped from the factory.
2hotchilis
Posted: 30 May 2021 at 11:13am |
Thanks for the pex size. We wouldn’t ever drive with the tanks full but appreciate you bringing that up. We are learning new habits to really cut down on our water consumption.
Darla
2017 R-Pod 179
2hotchilis
Posted: 30 May 2021 at 11:14am |
Thanks for the info.
Darla
2017 R-Pod 179
2hotchilis
Thanks for the help. We appreciate it. Off to Lowes now.
Darla
2017 R-Pod 179
Posted: 30 May 2021 at 2:14pm |
There are lots of posts on the forum about saving water boondocking. Biggest use is showers, second is dish washing. Toilet water use is really quite minimal.
We do the following. Wipe dishes immediately and thoroughly with paper towels, then let them stack up till after dinner. Around the time we start cooking dinner we turn on the water heater.
After dinner we wash dishes. Don't wait for the water to warm up. Wash dishes out of a small pot of soapy water using minimal soap. Rinse all dishes at once with warm water running at a slow rate and place in drainer.
Then take "Navy" showers (water is already warm). Wet down (20-30 sec) water off. Soap up, again minimal soap, then water on to rinse. Water is on for 1.5 to 2 minutes max. When done turn off water heater.
Also, we use water in 2.5 gallon dispensers for cooking, drinking, and brushing teeth. That extends the water supply and saves worrying about water tank contamination. We go through a couple of containers and the fwt in a week, so a total of about 35 gallons of which 30 goes in the gray tank and 5 or so in the black tank. Then dump and refill.
One other thing I did was add a second thermostat to the water heater which is adjusted to 105 degrees, so no fiddling with water temperature is required, just turn in the hot water and go.
2hotchilis
Posted: 30 May 2021 at 9:39pm |
Thanks so much for all that info. Saving all the dishes for one wash is a great idea. What we have done in the past is wipe all the dishes down then spray them with vinegar water solution, wipe them down again and let them air dry. It saves water and the vinegar cleans everything. \\
Darla
2017 R-Pod 179
