Page <1234> |
Author | ||
![]() Posted: 19 May 2021 at 11:39am |
The problem I think is going to be once starlink and it's competitors fill LEO up with anywhere near the proposed 100,000 or so 600lb satellites it will become a death zone. And terrestrial astronomy will be a memory. But money talks so it's gonna happen.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2710 |
+1 I don't know about Kuiper and OneWeb, but Starlink also has the "capability" to provide service to areas where there isn't a ground station. This means that Starlink can connect a dish to the actual internet instead of the state-controlled internet (e.g. China and Russia). I know for a fact that Russia has passed legislation that makes owning a Starlink dish illegal. It probably has Chinese bureaucrats working overtime. |
Think globally. Starlink and other constellation systems like OneWeb or Amazon's Kuiper are not designed *just* for US customers. Although ground stations are currently being used to beam backbone data to satellites, soon they will be transferring huge amounts of data between satellites via laser. Then it becomes a truly global system reaching far corners. No, it is not an urban solution where fiber is already available, but consider the 100's of millions of people worldwide who do not and will not have access to the internet via terrestrial systems. f |
I would agree except for the fact that the dish design is somewhat vulnerable to the conditions typically found around the homes of those 5 to 10% of people out here in the boonies: Strong winds, hail, debris blowing around, lawnmowers, tractors, cattle, goats, chickens, kids, yada yada yada.... I WILL be impressed when they sell a robust solution actually suited for life 'out here'.... Dishy McFlatface DOES look good sitting there on a well-manicured suburban lawn or perched on a purple plastic table on a cute little balcony next to potted flowers and a colorful hanging 'dream catcher'.....I will give you that. Miss soccer mommy can simply carry Mr Dishy inside when her wind chimes start to sing... ![]() |
Just FYI, Starlink is not intended for urban areas. I haven't seen them state it explicitly, but I remember reading somewhere that the system is not designed for heavy concentrations of subscribers. This system is meant for the 5% to 10% of people that are too far out of the urban area to get affordable broadband. It's the last mile problem.
This is a good current overview of cellular data plans:
f
Truly unthrottled data? Does anyone have that anywhere with ANY carrier? I doubt it. What this does is more or less unlimited, except, like always, it's 'limited'....but again, it's ONLY $20 per month. I get 22gb per month at high speed when on-AT&T network, nothing when I'm not. They can throttle it back after 22gb IF the tower is 'busy' or congested...whatever that means....but it has never happened in 4 years and I often blow way past the 22GB monthly data allotment. At any rate, it works for me, for now.
Starlink order acknowledgement says coverage in my area is scheduled for mid to late 2021. Saw a map today indicating a big belt of poor coverage currently extending up from FL through Appalachia. Looks like I'll be making an interest free loan of $100 to Elon for awhile. I'm sure he needs the money more than I do.
That's insanely cheap for ATT if it's truly unthrottled data. I have an old Mobile Share plan with ATT. Two phones share 6GB for $40.00. They claim it's unlimited by throttling anything over 6GB to 128K. Basically unusable beyond 6GB. I can burn through 6GB in a weekend no problem. We just use the Visible hotspot tethered to Gl Slate while traveling or at campsite....until I can stick that dish on top of the Pod. ![]() f |
Did you use my referral code??!! ![]() Just kidding.
Page <1234> |
