Page <12345> |
![]() Posted: 10 Mar 2021 at 7:00am |
+1 to olddogsrule. Lots of nice off the beaten path options if you’re not in a big hurry. I’d like to host on boondockers welcome this year assuming I can get some roadway graded in to a couple of spots. I’ve found things have gotten a wee bit mushy over the winter. Don’t want to get anyone stuck...
Hosting on BoondockersWelcome is free for the host....just sign up and offer up a spot or two. Caliche (2") is fairly cheap ($150/20,000 lbs delivered) and it works, but it does require a bit of maintenance now and then. Mixed with sand and spread around about 4-6" deep or so, then packed down with a heavy roller or tractor tires, its a very solid surface for parking vehicles on.
Yeah, I know what caliche is from growing up in the West. We don’t have it in the East that I’ve ever heard of. Clay and stone around here. There is a stone quarry about 3 miles from my place so I hope to get a decent price on the stuff, and I now have a tractor with a blade and box scraper so hopefully it won’t be too expensive. I’ll need to put in a couple culverts probably. But we just moved into the place Christmas so the roadbuilding project is probably about 10th on my list at the moment.
EchoGale ![]() Senior Member ![]() Joined: 10 Mar 2019 Location: FL Online Status: Offline Posts: 469 |
Would you share how to find you on BW?
Julie
My place is listed as Winford Station, Tulia Texas.
I have lots of dates 'blocked out', but if you were to pass thru the Texas Panhandle and want to camp a night or two, just hit me up here and we'll ignore the blocked dates.
Someone with an r-pod just booked a stay here for next weekend!
Thanks for this I will likely do that!
Julie
pedwards2932 ![]() Senior Member ![]() Joined: 21 Sep 2020 Online Status: Offline Posts: 333 |
I had one other question.....it seems like the use of a slide out is considered a no no at these stop overs. But on my r189 the slideout doesn't extend past the fender.....so I can't see where that would be an issue? Also if the truckers have such an issue with RVers at truck stops they should take it up with the travel centers that actively court RVers and some even provide parking spots specifically for RVs
Tars Tarkas ![]() Senior Member ![]() ![]() Joined: 14 Jan 2013 Location: Near Nashville Online Status: Online Posts: 1454 |
I have always put the slide out at truck stops and no one has ever said a thing, for whatever that's worth. You're right, Pod slide-outs just don't extend far enough for anyone to care. A big ol' 4 foot slide out might be a different matter... TT
FJ Cruiser |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6435 |
There have been a few stops I have made where it was tight enough that I did not extend the slide. However, most of the time, I do extend the slide. I try to find the most level spot I can. If there is a slope, I pull in so the vehicle is pointing toward the lower end so the jack can raise the front of the trailer, even while hitched. I use the Andersen leveler for side to side leveling. Then I lower the stabilizers using a drill-driver and socket. It is almost as fast as typing the description here. Then we can sleep well and the refrigerator is level for optimum operation. As others have said already, the slide does not extend out much past the fender so it is not a big deal to have it extended.
I did put reflective tape on the slide on the front and back right next to the flange so that if someone is pulling in next to us, the slide will be more visible. It is in an L shape on the bottom corners.
Page <12345> |
