  New Posts New Posts RSS Feed: R-Pod 190 windshield seal broken?
Topic ClosedR-Pod 190 windshield seal broken?
Dirt Sifter View Drop Down
Direct Link To This Post Topic: R-Pod 190 windshield seal broken?
    Posted: 26 Feb 2021 at 9:37pm
Originally posted by rcase13
The window is the main reason we waited for a later model. LOL hopefully that doesn't come back to bite us.😬
Lots of folks waited like you for the same reason. There was a problem with leaks around the window with the first run of 195's that had'em from what I heard so we looked for an early one without. That window should not be wet or have condensation in it. Keep us posted on what you find out. Be safe.
Greg n Deb 2020 195 HRE
rcase13 View Drop Down
Direct Link To This Post Posted: 26 Feb 2021 at 6:59pm
Appointment made. Hopefully it doesn't sit and wait forever due to supply issues. We just got it after an 8 month wait. We have only been out once.
2012 Ford F150 5.0l
157"WB 4x4 ELD
2021 R-Pod 190
Direct Link To This Post Posted: 26 Feb 2021 at 6:49pm
Originally posted by jato
Last I checked they do not have a cover for the window.  There have been member mods whereby they used velcro and put a 'shield' over the window to protect from rocks flinging up from the rear tires.  Unfortunately that doesn't completely remedy the issue.  Even with the shield in place there have been reports of the window breaking apparently due to the stress of twisting and torque on the frame as it is towed down the road.
I remember my parents 1964 Shasta had a front window and also had a plastic shield that protected it as they traveled.  Never had a breakage problem with that.  FR engineers need to find those Shasta engineers from the 1960's and find a solution to this ever growing issue.
Umm. Those Shasta engineers from the 1960’s have most likely gone on to greener pastures.
I used to design and manufacture solar modules, which use tempered glass. Sharp rocks can and will nick the glass surface and break them, and the only way to avoid that is to cover the glass with something rigid and protective that will keep rocks away from the glass. You can tell that glass is tempered if it shatters into small pieces. We had at least one member who reported tempered glass breakage on his front window.OTOH, tempered glass can take a tremendous amount of warping and twisting, way more than the trailer will survive, and not break.
The current issue wasn’t a broken glass problem though, it sounded like a double pane insulated glass unit that had lost its seal. That is a completely different issue, and could certainly be caused by flexing or vibration, nothing to do with rock chips because the glass didn’t break. So covering the front window wouldn’t solve it. This is not a one solution fits all
Issue, we need to understand and address each problem one at a time.
mjlrpod View Drop Down
Direct Link To This Post Posted: 26 Feb 2021 at 1:25pm
Hey, everyone has their own likes/dislikes. I think besides breaking, the front widow will be a leak source, let cold right into the bed area, and allow light in while sleeping. Honestly, even the rear is bad enough, but I can take that one, I just don't want to be in a fishbowl either.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 26 Feb 2021 at 11:33am
2012 Ford F150 5.0l
157"WB 4x4 ELD
2021 R-Pod 190
Direct Link To This Post Posted: 26 Feb 2021 at 11:17am
Originally posted by mjlrpod
Best solution: Stop putting in a big front window, especially if it's over the bed. I hate front window, and will not by another pod, or any model, that has one.
I find it interesting that on our 177, which has the window over the bed, has never been problematic.  It would seem like if they used the same type of glass and frame, and surrounded it with a similar rubber boot like they do on the rear side of the pod, why wouldn't it work on the front side?  Something is obviously different.  Unfortunately I have not seen one of these up close and personal to make an educated guess as to why there have been so many problems.
Direct Link To This Post Posted: 26 Feb 2021 at 11:12am
2020 R-pod 195
I'll be rpodding
Direct Link To This Post Posted: 26 Feb 2021 at 10:20am
Direct Link To This Post Posted: 26 Feb 2021 at 8:29am
I'll call the dealer today and see about getting it replaced. Do they make covers for these?
2012 Ford F150 5.0l
157"WB 4x4 ELD
2021 R-Pod 190
Direct Link To This Post Posted: 26 Feb 2021 at 8:19am
I don’t have a front window either but from other postings of broken ones I thought the front windows were single pane tempered glass? Already they making them double pane insulated glass units now? If so, that’s going to be an even worse breakage issue, I’d want to cover mine while in the road.
