Best Internet Options? |
Page <1234> |
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2709 |
![]() ![]() ![]() ![]() Posted: 04 Feb 2021 at 11:48am |
If you do get one of the satellite options, pay careful attention to the data volume limit. They have been getting more liberal in recent years, but I have acquaintances who run into their data limit on the 4th or 5th of the month. Then they have to access their account and put another $5 or $10 or something into the meter to get more. Then rinse/repeat every 4 or 5 days until the end of the month.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6428 |
Consider that many RV parks specifically say that video streaming is not permitted. Not that it stops people from the speeds I have experienced.
PilotPodder ![]() Senior Member ![]() ![]() Joined: 04 May 2016 Location: Portage, MI Online Status: Offline Posts: 305 |
I've worked remotely significantly and effectively over the past few years in a corporate setting (calls/VPN). I have AT&T on my iPhone and also a Verizon 8800L Jetpack as a back up. I also use a WeBoost Drive Sleek in my RV (set the antenna wherever works best) and cradle the iPhone when needed if the AT&T signal is weak (the WeBoost does work to increase the AT&T signal if there is one). Both the AT&T and Verizon I use the "unlimited" plans (100GB/30GB hotspot for AT&T, 30GB Verizon). It works well and allows me to toggle between the two major carriers as needed.
If anyone is interested I’ll put together a shopping list. Just please don’t expect miracles. I generally pick up a couple of bars if I have at least one to start with. The bars are a very subjective metric. Unfortunately Iphones no longer provide access to the actual signal strength data. Thanks for nothing Apple. 👎. I hear Android phones do still provide that data.
Keeping service with two different providers might be a good idea. Gives a better shot at picking up a tower. If you get one connected you can set it as a hot spot and make WiFi calls from the other phone using its signal. Edit: spoke to soon, looks like signal strength might be accessible again on the iPhone. Last time I checked it wasn't was disabled. Here’s how you access the field test menu: https://www.google.com/amp/s/www.macworld.com/article/3346027/how-to-see-your-true-cellular-signal-strength-with-the-iphone-field-test-app.amp.html |
From OG's post on this message:
The directional antenna is from Wilson Electronics as is the low loss coax cable. The booster is from WeBoost. They are affiliated companies. You also need an adapter to connect the coax to the booster antenna input and a telescopic pole and some clamps. Takes a few minutes to set up and find the best signal strength. Cost was about $300 or do IIRC.
Pod_Geek ![]() Senior Member ![]() Joined: 04 Dec 2019 Location: Colorado Online Status: Offline Posts: 261 |
Just as an FYI...when we need to get work done from the RV we select campgrounds that we know from experience have a strong WiFi signal or locations where we know/are pretty sure our cell signal will be strong (so that we can use a hotspot). The latter are usually near towns.
For any kind of video streaming you'll need a better connection than you normally get at most commercial campgrounds, although we have run in to some that have upgraded their WiFi to the point that streaming is possible. I don't know whether even the most expensive satellite options would be sufficient for Netflix.
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L |
SkeeterPod11 ![]() Newbie ![]() Joined: 28 Oct 2020 Online Status: Offline Posts: 16 |
Thank you all for your input. Please continue to post. So happy to have such a great community to lean on. & Im mainly in need of internet for netflix/video streaming and social media for work & emails/communication with family. I have AT&T as a cell provider and my girlfriend has T-mobile so we are exploring options regarding data and hotspot plans. I am also interested in options such as mention by offgrid. Your replys are greatly appreciated. Ive learn a lot from your input. Im going to continue to explore all options. Cell data Hot spot and satellite hotspot appear to be the best options. All posters feel free to post your data plans or providers along with capabilities and usages.
See my post above for what I have. WeBoost makes several versions, I just use the Slim which is their lowest cost model. Just don’t expect miracles. |
EchoGale ![]() Senior Member ![]() Joined: 10 Mar 2019 Location: FL Online Status: Offline Posts: 469 |
I'm often in paces where there is some, minimal but unreliable cell service. I don't have a booster but would be interested in buying ne. Any thoughts on considerations or recommendations for which one?
Julie
If SkeeterPod11 (aka the OP) is located/camps out west here there are plenty of places that have zero, zilch, nada as far as cell signals go. geewizard's question is a great one...what is the intended use? Email, Netflix, or something in between? If the former, then something like the Iridium GO! Satellite Hotspot might do the trick.
Page <1234> |
