  New Posts New Posts RSS Feed: Furnace question
Topic ClosedFurnace question
MitchReef View Drop Down
Direct Link To This Post Topic: Furnace question
    Posted: 23 Dec 2020 at 9:56am
I'm trying to figure out how the furnace works in my 2014 178. When I turn the furnace on it is from the regular wall thermostat. The AC fan immediately starts with the furnace. Does that mean it will not work without shore power?
Mitch and Laurie Carter....
Still rolling....
mjlrpod View Drop Down
Direct Link To This Post Posted: 23 Dec 2020 at 10:38am
You should have the fan set to auto, then turn on the heat. It should then light, and begin blowing out heat. It will probably smell too, especially if it hasn't run for a while. I usually have my bathroom vent open a little and the fan on low when I run heater.  It will run on battery, or electric.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 23 Dec 2020 at 12:48pm
My thermostat is a little round one with 1 botton for function and 2 for up and down. My curiosity is whether the ac fan runs on 12v?
Still rolling....
JR View Drop Down
Direct Link To This Post Posted: 23 Dec 2020 at 2:04pm
Yes the fan that blows the hot air from the furnace into the trailer runs on 12v and if my memory serves me correctly when the thermostat calls for heat the furnace will start the fan to make sure there is no build up of gas in the furnace before the self ignitor will light the LP gas.  Maybe that is what you are hearing is the purging of the furnace.  I am going by memory as to the sequencing, hope this helps.
Jay
179/2019
Direct Link To This Post Posted: 23 Dec 2020 at 3:30pm
Actually, whenever the furnace is running, the noisy roof ac fan runs. That's what I am curious about.
Still rolling....
JR View Drop Down
Direct Link To This Post Posted: 23 Dec 2020 at 4:30pm
Sorry I am bad didn't realize you were talking about the ac fan even though that is what you asked about...Dua...can't help with the ac fan running while trying to use the furnace
Jay
179/2019
Direct Link To This Post Posted: 23 Dec 2020 at 4:48pm
I can't imagine that it can run like this when on 12v. I think it would just eat a battery alive.
Still rolling....
Pete Brayton View Drop Down
Direct Link To This Post Posted: 23 Dec 2020 at 5:18pm
I think you turn off the fan on the thermostat and then turn on the furnace. The furnace fan turns on when the furnace comes on so the fan setting on the thermostat is for the AC. At least I think that is the way things work.
2021 Rpod 196
2013 Ford 150 V8
podwerkz View Drop Down
Direct Link To This Post Posted: 23 Dec 2020 at 5:30pm
If you are on shore power the A/C fan will run when the furnace is running unless you set the digital thermostat to the correct setting. I can't remember the setting, but if its on 'auto' try low or high, if its on low or high now, try auto.
The A/C fan will NOT run on battery power when unplugged from shore power.
Direct Link To This Post Posted: 23 Dec 2020 at 8:29pm
If the thermostat is the same as ours, setting the fan to Auto will keep the AC fan from turning on when the furnace calls for heat.
