  New Posts New Posts RSS Feed: Finally got our R-pod 196
Topic ClosedFinally got our R-pod 196
JR View Drop Down
Direct Link To This Post Topic: Finally got our R-pod 196
    Posted: 29 Jan 2021 at 7:55am
I think that the suspenders are beefy enough they just have to be put together the correct way.  Then you don't need a belt but it is always good to have a backup when dealing with black water.
Jay
179/2019
Direct Link To This Post Posted: 29 Jan 2021 at 7:42am
Maybe they should go into the history books and use the 'belt' once used on the older models.  The belts on my 2011 look similar but obviously used a beefier material in its construction as they have held up well over the past 10 years and 36,000 + miles.
JR View Drop Down
Direct Link To This Post Posted: 29 Jan 2021 at 7:35am
Looks that way and also it looks like they are still assembling the suspenders incorrectly, which is why they fail and need a belt.  What I mean by being assembled incorrectly is that there are 2 parts to the bracket 1) an L bracket mounted to the frame and 2) a round bracket that goes around the black pipe.  The round bracket should be installed on top of the L bracket and then the bolt installed to keep the 2 brackets together. The round bracket should not be supported by a bolt to the L bracket in my opinion.  With this change the L bracket is supporting the round bracket if it is mounted on top of the L bracket.  I have made that change with mine and have not experienced any more problems.  Hope this helps.
Jay
179/2019
Online Status: Online
Direct Link To This Post Posted: 28 Jan 2021 at 10:16pm
So they added a belt to go with the suspenders.
Ricktoon View Drop Down
Direct Link To This Post Posted: 27 Jan 2021 at 6:29pm
Here are some image of the black water outlet and gray water outlets on the 2021 R-pod 196
Rick and Ellen B
2019 Chevy Colorado
2021 Rpod 196
Direct Link To This Post Posted: 29 Nov 2020 at 10:19pm
Trailer in storage right now. Will take some pics when I get a chance
Direct Link To This Post Posted: 29 Nov 2020 at 12:34pm
Originally posted by Ricktoon
Glad to see Forest River has beefed up the black and grey water discharge pipes with additional support to the frame. All in all, a great travel trailer so far.
May we have a picture of what they've done to make it beefier?
Direct Link To This Post Posted: 29 Nov 2020 at 10:55am
I bought a Progressive Industries surge protector already and it works fine. Used it on the first trip. Will buy a short length of chain so I can lock it to the power box if needed. Just ordered a Serta hyrbrid queen mattress from Lowes for a great price of $329 that we will use to replace the short queen. Not sure of the quality, but hard to beat the price.  I plan to put lift arms under the bed and maybe extend the base just a bit for the longer mattress. Want to make sure I don't make it too cramped to get around the side. One of the main reasons for buying the 196 was the North-South bed where my wife and I can get in and out on the sides and not have to climb over each other to get out.  Will look at the rail replacement.
mjlrpod View Drop Down
Direct Link To This Post Posted: 29 Nov 2020 at 9:57am
I just added a 5 inch mattress topper, and it's tolerable. I think replacing it might be the better way to go if you aren't happy with it. A big mod I always suggest, is to get an EMS before all others. It will protect all of your electronics from high/low volts, and a bunch of other possible issues that could harm your camper. I suggest a hard wired unit, do it once and forget about it, but any type is better than none. The pantry shelf holders are not very strong. If you intend on putting much on them, I'd replace the plastic rails with steel rails. Mine caved in after a few months. I put lift arms under the bed, it makes it so much easier to use the storage. There's plenty of other things you can do, but that's a good start. Enjoy the pod, no matter where you camp, it's a million star resort
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 28 Nov 2020 at 3:16pm
Thanks for the update. Would love to hear what you recommend for mods.
BTW, have you replaced the mattress with a full queen. If so, how does it fit.
