Sgardner
Topic: RPod 178 Mystery Button - Second Owner Posted: 12 Oct 2020 at 10:31am |
Second owner of an RPod 178, Just inside the door on the left, above the television. We have a button set which indicates battery / grey water / clean water / blackwater. We have the slide button which moves the slide in / out.
There is also a black on/off toggle button on the left, no idea what it is for and cannot figure it out, any ideas?
It does not toggle a light inside or out, nor does it turn on/off the external speakers. Highlighted in red below.
Posted: 12 Oct 2020 at 11:18am |
Porch light.
Sgardner
Posted: 12 Oct 2020 at 11:20am |
Bulbs must be out then, i'll check light outside the door.
Thank you.
Posted: 12 Oct 2020 at 3:19pm |
+1 to Furpod, I have a 178, it's the porch light.
Ctvmotors
Posted: 23 Nov 2020 at 8:22pm |
Hi all, been lurking awhile after buying a one owner 2016 rp179, and I appreciate the intel here... re this outside light, how do I replace the bulb? On my first and only trip out, in figuring out switches, I found this switch, and light, which worked for several minutes, then went out. I presume the bulb is bad, but couldn't easily pop off the orange cover? Any tricks? Thanks, in advance, ddc
Donald Curtis, CTVMotors Garage, just down from the Mars Hotel
2016 RP 179; 2015 3.7 V6 F150; 2015 HD Road Glide
Four wheels move the body; two wheels move the soul...
Posted: 24 Nov 2020 at 6:45am |
Should be quite simple with a flat screwdriver put the blade in at the bottom of the lens, slightly twist the blade and the lens will pop off.
Ctvmotors
Posted: 24 Nov 2020 at 8:45am |
Thanks!
EchoGale
Posted: 24 Nov 2020 at 9:15am |
It feels like you're going to break it but it does pop off.
Julie
Posted: 24 Nov 2020 at 4:48pm |
Put a LED bulb in it.
