  New Posts New Posts RSS Feed: Dometic Frig RM8501
Topic ClosedDometic Frig RM8501
Grenna View Drop Down
Direct Link To This Post Topic: Dometic Frig RM8501
    Posted: 14 Nov 2020 at 11:51am
Will my Dometic Frig RM8501 work on Battery power and power from my tow vehicle while towing?
Grenna
RoverPod View Drop Down
Direct Link To This Post Posted: 14 Nov 2020 at 1:05pm
Your refrigerator will work on battery power from your rPod's battery. Whether or not your rPod's battery gets charged from your tow vehicle while towing depends on your tow vehicle and how it is wired.
What you are using to tow with?
2017 F150 XLT SuperCab
2020 rPod 180
Direct Link To This Post Posted: 14 Nov 2020 at 1:36pm
2016 Nissan Frontier 6 cyc
Grenna
Direct Link To This Post Posted: 14 Nov 2020 at 2:03pm
If you have a voltmeter or know someone who does go to the Bargman plug (7 pin connector) where you hook up the pigtail of the pod to.  The spade connector at the 11:00 position is your 12 volt feed and the spade connector opposite that (5:00) is your ground.  Hook up to those with your voltmeter.   With your Nissan running you should read 13.7 volts.  If not, you will have to get it checked out or wired so that you can power your refer while traveling.  Many here just travel down the road with propane.  Legal and safe in all 50 states.
Direct Link To This Post Posted: 14 Nov 2020 at 2:08pm
Propane then sounds like the way to go, thanks.
Grenna
Direct Link To This Post Posted: 14 Nov 2020 at 2:25pm
Don't count on the Frontier being able to both charge the battery and run the refrigerator. The gauge wire used for the 7-way is too small for the purpose. You would need to run a new wire of a heavier gauge to carry enough current for the task. You are better off running propane when not connected to shore power. I speak from experience.
I can do so now because I ran a separate power circuit with a battery isolateor in order to charge the LiFePO4 battery with a DC to DC charger. It provides enough power that I can now both charge the battery and run the refrigerator. I could not do that before.
2010 Nissan Frontier Crew Cab 4x4 LE
Pod People View Drop Down
Direct Link To This Post Posted: 14 Nov 2020 at 4:01pm
The fridge WILL run on battery power--but not for long! It is the least efficient way to operate.  Most people use propane unless connected to shore power.
Further, most tow vehicles will not be able to give a substantial charge to the pod while driving. It is totally acceptable and safe to use propane except in limited situations, like tunnels, ferries, and other enclosed places.
Vann
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 14 Nov 2020 at 4:39pm
The vehicle charge system is designed to charge the vehicle battery. It can't independently charge an auxiliary battery and allow an overcharge of the vehicle. It's not set up that way. There is a 12volt source in the 7 pin. It does supply 12V to the TT, but it is not regulated by the TT battery it is regulated by the TV battery. They sell add on auxiliary battery charging systems, several companies make them (REDARC), they are not cheap. The bottom line is your TV is not designed to charge two different batteries, it charges the TV battery and supplies a 12V source thru the 7 pin.
Direct Link To This Post Posted: 14 Nov 2020 at 5:26pm
I run my fridge on 12V while towing all the time. If you have adequate wire size running to the 7 way connector it should be fine. To maintain the rPod battery and run the fridge you will need 10 gauge or larger wire to keep the voltage drop low enough that the rpod battery doesn't get discharged. When you stop for the day you should change the fridge over to propane right away. Or, you can leave it on propane all the time except for a few bridge tunnels as others have noted.
Direct Link To This Post Posted: 14 Nov 2020 at 5:43pm
I do the same as you OG. I don't expect the TV battery to keep the TT battery charged, when I arrive I have a deplenished TT battery. However it keeps the TT reefer powered. When I arrive I switch to propane or camp ground power.
